Old 02-07-2009, 02:16 PM
crizdee's Avatar
crizdee crizdee is offline
Default strange pt8 ilok auth missing message?
Have started installing everything onto a MacPro and that is working fine!
But when i revert back to my G5 it now says the ilok auth cannot be found on the ilok but its definitely there and the ilok is plugged directly into the G5 and i have tried all USB sockets
Any ideas?
Producer, Engineer,
www.ukmastering.com
Old 02-07-2009, 03:15 PM
crizdee's Avatar
Default Re: strange pt8 ilok auth missing message?
Totally bizarre! this ilok works fine on my MacPro but no longer works at all on my G5
Have tried all obvious stuff, latest pace drivers/repair permissions/different USB ports etc.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-07-2009, 03:39 PM
KingFish KingFish is offline
Geeze - thats scary - did you install BOTH the Interlock drivers AND the Interlock TOOLS?
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Missing iLok Auth after updating to 10.3.7 [email protected] macOS 1 08-20-2013 06:15 PM
Pro Tools sudden "missing iLok" message when connected external USB devices. mgoorevich macOS 5 01-04-2012 02:13 PM
Getting regular "missing Ilok" message after upgrading to V9 SD2 macOS 5 01-26-2011 12:46 PM
Transfer iLok auth. from old iLok to new 003 factory iLok? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-20-2007 07:05 PM
ilok auth backwards compatibile - PT7.3 auth run 7.2? Barnaby Bristol Post - Surround - Video 2 06-20-2007 09:30 AM
