MIDI cc resolution/density
Is there any way to record MIDI ccs at a more fine resolution? If I am recording it in I get one event per 40 ticks. The line tool draws one event every 60 ticks. Very coarse. I can get it much finer adding points manually as shown in the image. Did I miss the setting for this somewhere?
Re: MIDI cc resolution/density
What are you using for your fader/recording input device?
What is your midi interface or usb depending on what you are using for your input device)? In preferences, mixing, there is a "smooth and thin data after pass" setting but as coarse as yours is showing, that seems like a problem with communication from your fader to pro tools. Or a hardware failure with your fader.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
The freehand section looks like it was done via mouse. |
go to preferences -> MIDI -> Pencil Tool Resolution when Drawing Controller Data -> done
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Btw i don’t understand why the density is in ms not ticks (or selectable)...
Thanks for replies everyone. I realize now I was looking at it the wrong way and also the example I posted wasn't a good one. Actually that was the recorded midi output of a plugin that generates midi data. Seems like no matter what I try with the settings of that plugin, it won't give me smooth output.
The reason I assumed it was Pro Tools' fault was that when I record pitch bend from my midi keyboard I get the same steppy result but with 3-4 breakpoints on the start of each step. So it looked to me like Pro Tools was quantizing the data. Still don't know why there's several break points on the vertical part of each step. may be a hardware issue. Recording from my midi keyboard controls gives me midi data with a resolution of around 9ms (not ticks, thanks clausiii), so it's not as bad as I thought, really... Last edited by ibbod0; 12-22-2018 at 03:03 PM. |
High resolution 14 bit MIDI automation | gdgross | Pro Tools 2018 | 1 | 09-21-2018 01:24 PM |
Split tracks to multiple drives for high density editing sessions? | audiogeekzine | Tips & Tricks | 6 | 06-08-2009 09:06 AM |
Mix bus density... | Phil71 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-27-2004 07:56 AM |
Increase vertical resolution in MIDI track | Tim Goodwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-19-2002 04:28 PM |
9073 errors on cycle & hi track/edit density | plazonby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-13-2002 12:10 AM |
