Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 08-17-2017, 05:36 AM
TrackerLe TrackerLe is offline
Default How to stop Eucon from automaticly switching applications
Hi forum...
I have a problem with Eucon...
I am using a S3+Dock combo...
Everything is fine when working with PTHD and Logic...
But if switch from Protools to another application like Firefox, Eucon changes to Firefox and all Faders go down till i switch back, then all faders go back to session positions...
How can i tell Eucon, that it should only control Protools, even if i switch to firefox or Itunes...
Is there any option to prevent Eucon to switch automaticly apllications...
thx for help
Old 08-17-2017, 01:46 PM
reichman's Avatar
reichman reichman is offline
Default Re: How to stop Eucon from automaticly switching applications
There is a "lock application" setting in EuCon. Not in front of it right now, forget which tab, but it's easy to find. Put the application you want locked on top, then go straight to EuCon settings and lock.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 08-29-2017, 03:05 PM
jkess jkess is offline
Thanks Nathaniel.. :))
Old 09-02-2017, 06:36 AM
I found the Lock options... Thank you; This hint was really great... thanks
Old 09-02-2017, 10:15 AM
Mark Ziebarth Mark Ziebarth is offline
But you can lock the hardware to one application at a time only. It would be an improvement to lock it to Pro Tools and Logic (or any other DAW) for example.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control
MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate
Old 09-11-2017, 10:06 PM
danpt danpt is offline
Mark - Locking is an exclusive action and only works for one application. What would happen if you locked to Pro Tools and Logic, but then switched from Pro Tools TO Logic, which app should the S3 lock to and maintain the positions of?
Old 09-12-2017, 07:58 PM
EddieJones's Avatar
EddieJones EddieJones is online now
I think what you want is an option to only switch to EUCON Apps (like the S6). I'll have a think.
Old 05-09-2018, 08:13 PM
Dizzi45Z Dizzi45Z is offline
I have both Pro Tools and Logic in my studio and I would like a control surface that easily switches between the two. Currently, a HUI system I have requires that I go through a lengthy process to switch. In searching to see if the S3 would switch back and forth, I came across this thread.
From what I am gathering here in the thread, it sounds like the S3 automatically switches between applications without having to re-set-up settings.
I don't want to hijack this thread. I just wanted to confirm that this is the case with the S3.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 05-09-2018, 09:08 PM
reichman's Avatar
Dizzi: I can confirm that the Dock switches instantly and smoothly between Logic and PT. Pretty sure S3 would too.
Nathaniel Reichman
Old 07-13-2018, 04:24 AM
jKat74 jKat74 is offline
Hi, I have the same problem with System 5 MC. The C408T Modules bring down all faders when I switch to other applications. How can I do to lock them to Nuendo 8 app? Thank you
HOW TO STOP Protools changing audio interface automaticly when another is connected EdwardG Pro Tools 12 4 05-23-2017 05:48 AM
Unable to add applications to Eucon system preferences ShiftStudios Artist Series 7 06-12-2015 06:10 AM
Eucon Preferences, cannot add applications hoeglund Artist Series 2 05-08-2015 03:38 PM
Artist Control still crashes when switching between Applications romanoffski Artist Series 2 12-09-2014 03:07 PM
Issue with 8.0.3 and switching to other applications JWalkerPostAudio Post - Surround - Video 3 01-12-2010 02:06 PM
