Old 08-03-2016, 01:26 AM
thanos4 thanos4 is offline
Default UNDO sometimes stops working!!!!
Just got embarrassed myself in front of a client twice these days...
I was working on a session (about 80 tracks including VIs) and we were making some arrangements in midi editor..When the client wanted to undo some stuff...the UNDO command didn't work at all...including audio...meaning when i dragged a clip to the left in timeline when hitting undo, the clip didn't move to previous position...
I thought this was just a bad day for the app because i was working on it for 10-11 hours ...but this happened again yesterday, about after 1 hour of working or so...
However,if i close the session and reopen it,undo command seems to work again...but that's not the case
Don't think i had this issue before 12.5.2
Anyone has similar experience?
Old 08-03-2016, 07:52 AM
PhilG PhilG is offline
Default Re: UNDO sometimes stops working!!!!
Strange but wouldn't put it past Pro Tools. When you Say "However,if i close the session and reopen it,undo command seems to work again...but that's not the case".
When you close the session and reload it, undo functions for previous changes or the changes you make after reopening. Its a pain if that fixes it because you have to keep doing it.
Windows or Mac?
Old 08-03-2016, 08:23 AM
Windows or Mac?
Hi PhilG
I meant that if i close the session and reopen it,then the undo function come back to life...
I am on mac 10.10.5
Old 08-03-2016, 08:58 AM
john1192 john1192 is offline
Originally Posted by thanos4 View Post
Hi PhilG
I am on mac 10.10.5
restarting PT yes fixes, but that Clears the Undo History so all of those changes are lost .. i would really like to see the undo history be intact for our entire sessions .. why do we have to lose this .. ??? makes going back a bit very very hard ..
i still want to see the undo history come back to normal - using Commit still Clears the History once Commit is undone .. it is being looked at but no fix yet .. hang in there ... i am sure it will be restored to pre-Commit behavior ..
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 08-03-2016, 09:56 AM
The Weed's Avatar
The Weed The Weed is offline
I would very much like to see the unlimited, selective undo of Nuendo/Cubase - at least they used to have it. Every action is stored in a file and never flushed unless you chose to do so. (Pro Tools has several actions that will flush the undo cue, commit's being undone just the latest.) When I say selective, here's what I mean:
Say you have done 10 actions and want to undo number 5. In other programs, not just Pro Tools, you would undo back to number 5, then have to rebuild your actions back to now number 9. In Nuendo/Cubase you would simply delete number 5 from the undo cue and the program would rebuild back to now number 9. In other words, once number 5 is deleted, it's like that action and it's effect on subsequent actions never happened. Brilliant. And yes, IIRC, I added this to IdeaScale several years ago. I've certainly posted about it before.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-03-2016, 10:02 AM
I cant remember the details, but there is an action that is deleting your undo que. I believe it might be undoing commited or frozen audio. I know there is a bug about it, but cant recall it 100%
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 08-03-2016, 10:03 AM
Extreme Mixing Extreme Mixing is offline
I believe that's the way DP works as well.
Steve
Steve Shepherd
Extreme Mixing
Old 08-03-2016, 11:08 AM
soybalm soybalm is offline
If you leave the undo history open, you can go back and forth between undo states. But if you select the middle point of your history AND perform any undoable action, you will lose the most recent undos. That works that way in Nuendo I do believe. Some programs have an option to save undo history upon closing. You might have to resort to a save as series if necessary.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 08-03-2016, 01:17 PM
I got hit with that a few days ago(also 12.5.2). Then today I got a string of crashes while trying to import tracks(session data) from a session I just closed After a system restart, import worked fine. I still get lots of system "burps"(which never happen on 11.3). System usage meter sits at below 25% but has the dancing line that bounces between 30 and 85%, and if it pops to the top and turns red, PB stops with the "burp" noise. Fun fun
Undo command not working in Pro Tools HD 10.3.3 dj_tms macOS 6 05-01-2016 11:37 AM
MIDI Thru stops working after sequence playback stops kelcarpenter MIDI 20 03-16-2016 11:43 AM
Undo not working when pasting automation to a different parameter johan2006 Pro Tools 12 0 12-15-2015 11:01 AM
'undo' not working in mix window??? fm_xtk Pro Tools TDM Systems (Mac) 4 02-23-2009 12:39 PM
Undo not working and then access violation Brandonx1 Pro Tools TDM Systems (Win) 4 02-19-2007 10:26 AM
