trim/extend multiple regions
is this now possible without the dreaded batch-fade workaround which doesn't work when regions need to be shortened to less than half of their original length.... |
Re: trim/extend multiple regions
Select multiple regions by pressing and holding the command button, and keep holding the button while trimming the start position. I think it was the command button, but might remember it wrong though.
However, this only works if you want to set the start position to same time for all regions. If your regions have different timings then this won't help you.
i'd like to fine-tune kick and snare hits that are strip-silenced. i know all the functions of strip-silence, but e.g. in a dynamic performance i need to work section by section. i don't want to redo the strip silence just to experiment with region-length late in a mix. sometimes i need to shorten kick samples, sometimes i mult a stripped kick-track to send into distortion, somtimes i need to 'design' a kicktrack for sidechain only... many situations where the batch-region-length-change would come in handy... |
Simply drag-select all the clips you need with the object grabber tool (the last one in grabber drop down menu), and then use Option+Shift+“+/–” to trim clips' start, or Command+Shift+“+/–” to trim the ends. Trimming follows the nudge value you have set in the nudge counter. Hope you find thus helpful!
PT 11.2 Mac |
i don't know what i'm doing wrong but the modifiers don't do anything... the clips are only nudged in time (as if only +/- are used), but no combination does anything to the boundaries... (i tried transport & classic mode) PT 10.3.2
just skip the [shift] key and I think you'll be fine. Works like a charm on PT11! Recap: To edit length on multiple clips: Select the clips with the OBJECT GRABBER tool , then use [Option] +/– to trim clips' start, or [Command] +/– to trim the ends. Trimming follows your nudge value. Thanks /E |
Thanks E for sharing !
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
works also in PT10
thanks for sharing! still very useful after one year |
THANK YOU! You just saved me an entire hour. I applaud your kind sharing of this vital information.
The option +/- did not work for me??
Trim regions across multiple tracks? | Dave Labrecque | Windows | 16 | 08-15-2011 04:28 PM |
Possible to trim or extend multiple regions at once? | Mike Greene | Pro Tools TDM Systems (Mac) | 5 | 02-05-2008 01:57 AM |
can you trim many regions at once? | se.audio | Tips & Tricks | 10 | 07-24-2006 06:52 PM |
can you trim many regions at once? | se.audio | Tips & Tricks | 0 | 07-19-2006 03:28 AM |
Move/Trim Regions vs. Logic | Zep Dude | Tips & Tricks | 0 | 02-24-2000 09:02 PM |
