Video File Server with Pro Tools
I was Just wondering with my big head, can I run my video drives from a file server to Pro Tools (not my PT Files, just Video from projects)? EX. I would Run my session with my audio files on my Workstation PC, and add video that would access video through a 1000Gb switch (with no internet connection on that channel).
www.M-ManLA.com www.facebook.com/MManLA www.soundcloud.com/m-manla Pro Tools 12, Sibelius First 7/Presonus Studio 192/Windows 10 Pro |
Re: Video File Server with Pro Tools
Yea I was wondering. It would be nice to have PT Satellite on the LE Systems as well.
Not sure either,but i think that they should be NonRaid, and designated as P/T on the WorkSpace
Yes it can be done. I got a SAN from a supplier http://www.2degreesfrost.com/ This uses SATA over ethernet and you need a copy of Fibrejet for each Pro Tols system that you connect to the SAN. We are running 3 systems, 2 edit and a Mix system, from the system with no problems at all. We can run complete Pro Tools sessions from the SAN over ethernet. You can use the spare ethernet port on the new 8 Cores so there is no need for a separate card. Setup is simple and the unit is relatively inexpensive compared to other Video SAN's.
Robin, who is the main person at 2 Degrees is very helpful, we took a punt on this and got it shipped to Australia and we have a spares kit. hope this helps Simon L. |
Yes you can play video from a video server. We have a large Xsan based video server and are able to play the videos in PT without a problem (you get a message that the video is on a non play back drive when you load a session or import a clip but if you click cancel it works anyway). You can do this via gigabit ethernet too. But I would recommend testing before making any purchase :)
Pete |
OK. My thing is that I am starting to get into video, and I use Sony Vegas. I am planning to have a render machine that will double as a video server. Now that I know people is using it, what is your setup like? do you have any photos or links?
Hi sleadley,
I'm interested in knowing what kind of protools performance you are experiencing? Have you tried any beat detected drums with tons of crossfades and high track counts on multiple machines? I was seriously considering that solution but couldn't afford it not to work and no local dealers. So I passed. I don't do video much myself, mostly mixing and the sessions are very often very large. Would love to know more about it's performance abilities. Thanks! Mike |
cutting Video file BUG Pro Tools 9.0.3 | mikehotten | macOS | 1 | 08-28-2011 09:47 AM |
Help!! Can't import the selected video file. (Pro Tools 8) | elsterNJ | Post - Surround - Video | 2 | 10-27-2010 06:22 PM |
Files transfered server-server relay still downloaded from remote server | Phill Barrett | Aspera DigiDelivery | 1 | 03-19-2010 01:58 AM |
my pro tools can't extract audio from M4V video file? | jonboi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-28-2009 01:13 PM |
Converting Video file for Pro tools | LucasM | Tips & Tricks | 3 | 03-20-2007 02:54 PM |
