Old 01-17-2008, 06:04 PM
soundfx soundfx is offline
Default Crane Song
So I just bought the Crane Song plugs for some music mixing I'm doing and it kind of blew my mind. I've started applying it to the mix buss and occasionally the VO for TV promos when necessary. Just wondering if anyone else is using these plugs for post. I love em.
-SFX
Old 01-18-2008, 05:18 AM
manichouse manichouse is offline
Default Re: Crane Song
I use it sometimes on vo, and on thin, harsh location sound. Definitely helps take some of the edge off.
Martin Trum
Old 01-18-2008, 03:20 PM
matt-o- matt-o- is offline
same just happened to me. I edited and mixed a short movie and experimented a bit, to see, if there any virtues in using these tapeemulators/harmonic generators. while inflator is too much low mid/hi bass emphasizing, which did not work so well for me with voices, Phoenix really sounds amazing. The automation works fine and after 3 days demoing I knew, I would keep it for the mix. I immediately bought it, because it is well worth it.
I started last year expanding my tool palette with transmod and inflator (and warmth of the dynamics) and found interesting different ways in dealing with sound and dynamics as opposed to using simply an eq and compressor plug. very inspiring tools also to deal with foley treatment, adr and so on.
Although the work ITB definitly is less linear and staightforward than with classical mixing techniques (and also really less capable in regards to complex settings), I meanwhile feel a little cumbersome working on Harrisons MPC, because it is so simple (which is also an advantage) and less sophisticated as regarding technical means (of course with the exception of MPC4D, but thats a different league as well).
But back to the issue, Phoenix is now my new first choice for Dialog (only subtle settings), inflator works better with fx for me, transmod is a sacred tool to deal with transients. It helps to rescue roomy or muffled dialog. I tried McDsp Analog Channel some years ago and could not use it for post work, massey tapehead is fine for phone distortion (if I am too lazy to fiddle with speakerphones parameters, which is also a gorgeous plug) and I had not tried digis reeltapesuite. and with those plugs i've got now, I am pretty much satisfied and will finish trying unknown stuff (for now).
I will see, what the experience with these plugs will be with the next months work...
have a nice weekend
matthias
MacPro Sixcore 3.3 GHz, 24GB RAM, HD native
PT 11.3.2, 10.10.3
www.imdb.com/name/nm0501611/
Old 01-20-2008, 06:17 PM
ripple FX ripple FX is offline
I use a Phoenix Iridescent plug on the mix bus of just about everything I mix.
http://www.ripplefx.com
Mac Pro 8 core 3.0GHz Harpertown
Magma PE6R4I - HD 3 Accel +1 Process
Control 24 - 96io - 1622
OSX 10.6.8 - PTHD 10.3.10
Old 01-21-2008, 10:34 AM
friendlybunny friendlybunny is offline
Yes... I use them all the time for thin or harsh sounding dialog. I also use them for FX, specifically gunshots, explosions and crashes.
Occasionally I will put iridescent on the mix bus to "glue" the mix together, if it needs it.
HTML code is On
Crane Song Phoenix AAX Stereo? yamahadrums AAX Plug-ins 3 10-24-2012 08:55 PM
FS: Crane Song Avocet kiddakota Buy & Sell 0 07-29-2012 04:34 PM
CRANE SONG Phoenix ukoomrann Pro Tools TDM Systems (Mac) 3 01-14-2006 04:12 AM
Crane Song STC-8 on mix buss will replace....??? fingerz88d General Discussion 2 10-20-2005 08:40 AM
FatSo Vs Crane song Hedd...... Rainchild Tips & Tricks 5 12-26-2000 05:03 PM
