19.12?
HI There.
Is there a new OS/Eucon update? Just checked my account and found out that 19.12 AVID S6 SOFTWARE. Best R.
Ricardo Cutz Re-recording mixer/sound editor supervisor. Http://106db.com.br ----- |
Re: 19.12?
I see that too. . There's no "What's New" in the "all docs" zip. .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Re: 19.12?
EUCON 19.12 for S4 & S6 addresses a number of bugs including the following:
• After attentioning a track, the Master Module and surface draw much quicker than in previous versions • When a function was auto expanded or sent to the attention expand knobs the knobs for previous inserts could flash on the surface before going to the correct insert (GWSW-12029) • It was possible for Attention Expand Knobs to fail to open plug-in windows on initial selection (GWSW-12601) • It was possible for the Function Scroller become unable to be scrolled to the right after expanding Inserts (GWSW-13139) • It was possible for Attention data to remain on MTMApp after quitting WSControl or changing focus (GWSW-13146) • It was possible for DADman Sources, Soft Keys, and controls to be missing on initial startup (GWSW-12967) • It was possible for the WSControl memory usage to increase over time (GWSW-12821) • The Soft Key “Repeat” function could fail to repeat (GWSW-13221) • It was possible for the MTM app and surface to struggle or fail to connect when loading a session (GWSW-13033) best, Jeff |
Re: 19.12?
Thanks Jeff.
Re: 19.12?
There should be a readme in the account ?
Re: 19.12?
Sorry Ed' it's not there. .
Re: 19.12?
level metering in the fader module disappears after updating. Is there a preference to it? Because I have being using it since it was implemented that I did no remember ( pro tools option is set to pre-fader metering) editing: all metering has gone. Metering in MMT also is not working!
Re: 19.12?
Have you restarted PT machine after updating ?
Re: 19.12?
yeah. both. will try once again.
EDIT: Needed a few re-starts but it is all back.
Ricardo Cutz Re-recording mixer/sound editor supervisor. Http://106db.com.br ----- Last edited by rcutz; 12-09-2019 at 09:41 AM. |
Re: 19.12?
Dmg Equality no showing properly after update.
Plug-in up to date. Re-starts and shut down - power up already made. *♂️ Edited: have turn back to 19.9 but before I made a ”collect files” is it of any interest?
Ricardo Cutz Re-recording mixer/sound editor supervisor. Http://106db.com.br ----- Last edited by rcutz; 12-10-2019 at 07:19 AM. |
