Old 06-01-2013, 07:53 AM
John Link John Link is offline
Default Naming of clips when audio file ends with a number
When using an audio file whose name ends with a number, I would like Pro Tools to append a number when I create new clips rather than changing the number. For example, if I have an audio file named "guitar 5-18-13" and I separate it into two clips, I would like the new clips to be named "guitar 5-18-13-1" and "guitar 5-18-13-2" rather than "guitar 5-18-14" and guitar 5-18-15". How can I get Pro Tools to do that?
I've tried unchecking "Auto-Name Separated Clips" but it had no effect on the behavior described above.
Old 06-02-2013, 06:18 AM
joachim's Avatar
joachim joachim is offline
Default Re: Naming of clips when audio file ends with a number
In PT 10.3.4, if you devide the clip "guitar 5-18-13", it will become "guitar 5-18-13" and "guitar 5-18-14" (not "guitar 5-18-14" and "guitar 5-18-15" as you describe).
If you do not use the "-" (minus) for the last number, but "_" (underscore) or " " (empty space), then "guitar 5-18_13" splitted will become "guitar 5-18_13-01" and "guitar 5-18_13-02".
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 06-02-2013, 08:10 AM
I'm using PT 10.3.4 and the naming of the clips works as I describe, as shown in the attached graphics files.
That solves my problem perfectly. Thank you.
File Type: png Screen shot 2013-06-02 at 11.06.47 AM.png (6.7 KB, 6 views)
File Type: png Screen shot 2013-06-02 at 11.02.17 AM.png (8.8 KB, 9 views)
Old 06-02-2013, 09:05 AM
joachim's Avatar
If "guitar 5-18-13" is a whole-file-audio, then the split clips will be "guitar 5-18-13" and "guitar 5-18-14".
If, in your case, "guitar 5-18-13" is a part of a mother-whole-file-audio then it works as you described. (Sorry, I did not do my whole homework.)
Glad, I learned something and was able to help !
Cheers,
Joachim
Old 06-02-2013, 11:52 AM
No, with a whole file it works as I described.
Old 06-02-2013, 04:36 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Once clips are split, Strip Silence can rename selected clips in various ways
Although I do like the underscore tip!
PT10: Naming & Coloring Clips TaoMokoda Windows 6 04-16-2017 08:54 AM
Importing clips in Pro Tools 10 / clip naming legasafe Post - Surround - Video 3 10-20-2012 05:44 AM
Elastic Audio file/region naming jem777 Pro Tools M-Powered (Mac) 0 06-05-2009 04:25 AM
AUDIO FILE NAMING vjk Pro Tools M-Powered (Win) 2 07-13-2007 07:51 PM
PT/AV XL 5.1 Spotting & naming video clips Robin Hollings Post - Surround - Video 0 05-07-2001 04:23 PM
