  #301
Old 05-09-2014, 01:43 AM
Moondog Moondog is offline
Default Re: New Hackintosh / PT7 monster HD PCI Rig
Hi Sonorelli,
I was looking at the GA-H55-USB3, but it isn't available in the UK.
I did finally get the Jetway NAF93-Q77 working, but it wasn't easy. The HD4000 graphics are still not quite QE (No youtube for example). Also the Geekbench score for my i7 3770 is WAY low at only 11,000. Can't see how others are getting 14k+
However, I am still happy. Compared to what we had before the whole system is much faster, twice the CPU power, 16Gb RAM, could fit another Accel card in to make HD3, plus the biggest boost was provided by switch to a 480Gb SSD. Pro Tools 9 HD lives out its twilight years in a 5 star TDM rest home.
As this is for a commercial studio, stability and speed are the main concerns, not minor cost, and this can run everything we can throw at it. For the moment of course...
Thanks everyone for all your help.
Moon
  #302
Old 05-09-2014, 07:00 AM
sonorelli sonorelli is offline
Glad to hear its working. You can tweak it during down time. The Gigabyte GA-H55-USB3 has been discontinued for quite some time now. The only place you could find one is eBay or similar. However, the GA-P75-D3 is readily available on Amazon for $100. I'm pretty sure there are a bunch of documented builds of Pro Tools rigs with this mobo.
Sonorelli
HD3 Accel PCI-x, Pro Tools 10.3.9 HD, OSX 10.8.5
Hackintosh - Gigabyte GA-H55-USB3, i7-870 2.93 GHz, 16GB RAM
  #303
Old 05-14-2014, 08:40 PM
fakejosh fakejosh is offline
Originally Posted by Moondog View Post
Hi Sonorelli,
Moon
Hey Moondog,
I have the same board and got it working quite well, except I can't get any of the uSB 3.0 ports to work. Can you confirm if they work on your system and if you did anything to get them going?
Thanks!
J
  #304
Old 05-15-2014, 04:20 AM
JOCKER's Avatar
JOCKER JOCKER is offline
Default Re: New Hackintosh / PT7 Sandy Bridge HD PCI Rig !!!
Mondog I have the same issue on USB3 ports on my gigabyte P75-D3... I heard about USB3 hubs recognizes legacy usb devices. Maybe works
  #305
Old 05-15-2014, 04:22 AM
JOCKER's Avatar
Hi J ;
Look at post above
  #306
Old 08-14-2014, 01:53 AM
Dimak415 Dimak415 is offline
Guys,
I have to tell you. The JNAF93 was one of the easiest builds I've ever done.
Make sure to use an Ivy Bridge processor like a 3770 (no K series required since you can't overclock with the Q77).
You'll need Mavericks 10.9.3 or 10.9.4.
Unibeast (check out tonymacx86)
What works:
No DSDT needed for UEFI (though I may patch one later)
Install went great. Just wait for the white screen to go into install. Took 5 min.
DVI works (HDMI untested) HD4000 video works OTB
Both LAN ports work
Looks like the slow iLok problem is solved with no LAN Kexts or futzing
32 Gigs of RAM @ 1600mhz using XMP Profile
All Intel 7 series Storage SATA ports are visible
Let me know if you have questions.
  #307
Old 08-14-2014, 08:43 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default New Hackintosh / PT7 monster HD PCI Rig
Nice - who is the oem for the JNAF93 board
And you could load 10.8 if you wanted right?
Daniel
  #308
Old 10-01-2014, 03:21 PM
temetrepo temetrepo is offline
Jetway is the oem
yes, you could load mountain lion if you want
Originally Posted by JustinA
"Soon" as in we should be refreshing our browsers, or "soon" as in ADC coming to LE?
  #309
Old 10-20-2014, 03:24 PM
volkil volkil is offline
Originally Posted by Dimak415 View Post
Guys,
What works:
Both LAN ports work
Hey Dimak415,
I have the same Jetway board and just build my hackintosh (10.9.4).
I wonder what ktext you used for the second lan port (82579lm), and whether you did get the usb 3.0 ports working at 3.0 speeds or not. If yes, how did you managed that?
Asus P5WDG2 ws pro
Intel Quad Q6600 @ 2.40 ghz
Corsair XMS TWIN2X2048-6400C5 G (4 x 2 GB installed)
Win 7 / OS 10.8.2
Apogee Rosetta 800 192k
PT10.3.2 HD
  #310
Old 02-05-2015, 07:41 AM
MSB Mastering MSB Mastering is offline
I've tried installing PT 8.1.1 rather than 8.032 (or something) on my jetway running W7 Pro 64 bit, but I get a message saying that I'm missing msvcr71.dll
I can download the .dll but I'm not sure which folder it goes in - some say the syswow folder, others the System32 folder.
Any ideas?
Thanks
Hackintosh for Pro Tools 7 - 7.4 anybody ? zavid Pro Tools TDM Systems (Mac) 0 02-19-2014 03:51 PM
Hackintosh Problem pocketcalc macOS 2 07-08-2012 05:35 PM
Hackintosh with PT9 HD Native? PMedia macOS 9 07-11-2011 09:12 AM
Hackintosh on my rig? Raoul23 Pro Tools TDM Systems (Win) 7 07-01-2011 03:26 PM
Hackintosh Help HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-16-2010 10:45 AM
