MBox MINI or MBox Classic (Original)
Just got an IBM X31 Laptop. Cute little 12". It has 1GB and a 1.4 Pentium M Centrino. I plan on getting a Firewire External drive. Which would be a better choice to get - The Original MBox or the MBOX mini? I already have a Digi 001 running Pro-Tools 6.1. The benefit of getting a Classic MBox would be direct transfer and portability. Of course with the MBOX MINI, I'd get PT 7.3. Could a 1.4 PM keep up with 7.3 for light track work (maximum 12 tracks in a session)?
Please help. Thanks.
Macbook Pro 15" (Mid 2014) 16GB RAM 512GB SSD Pro-Tools 12 2.5GHz i7 Quad Core |
Re: MBox MINI or MBox Classic (Original)
What do you mean with direct transfer and portability? Mbox mini must be easier to carry around than the original Mbox and they're both able to run the same software. The mini only records one channel at a time though if my memory serves me correctly.
What I meant was the MBOX MINI is smaller, lighter and MORE portable than the MBOX. When I said "Transfer", I meant that since my MAIN system is a DIGI 001 running PTLE 6.1, I could edit it directly using 6.1 and an MBOX on the go without having to worry about the conversion involved when working with two versions of the same software. If I was to edit my files on the go using PTLE 7.3, I probably couldn't dump it into my main system since it's running 6.1.
On the other hand however, my Laptop's processor is a COZY 1.4 Pentium M (which they say is comparable to a P4 running at 2.8 gHz) and has 1GB (I can upgrade it to a max of 2GB). Would that be too slow to run PTLE 7.3?? My main system has a P4 1.8 gHz processor with a 533MHz FSB and has never choked up in a session, even with 32 tracks and at least 10 AUX tracks. Then again, that was running PTLE 6.1
Also, the MBOX MINI canNOT run PTLE 6.1. Support for PTLE with an MBOX MINI starts at 7.1.
I think I would go with a MINI as it it gets you in essence a free upgrade to 7.3 an new ignition Pack etc. But the fact that you are limited to 6.4 on the 001 needs to be considered also. A Original Mbox would let you run 6.4 or upgrade to 7.3 if you so desired.
As far as i know you can record both channels with a MINI although only one has a Mic Pre. Frankly my MINi is a dongle......
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Thanks for the info, but my question is IS A 1.4 GHz PENTIUM PROCESSOR EFFICENT ENOUGH TO EFFECTIVELY RUN PRO-TOOLS 7.3 WITH AN MBOX MINI. I HAVE 1GB OF RAM (should I upgrade to 2GB?)!
Thanks
No one can really guarantee what a older laptop will do but a year or so ago or so the Pentium M laptops were doing better than a lot of the P4 Desktops. You should be fine. That said. Laptops and PT are notoriously finicky though. You might want to search the DUC and the "Best laptops for PTLE" threads with your computers model number and see if it turns up any info.
For tracking purposes 1GB should be fine. If yuo use heavy plug-ins and/or VIs then you should def look into another 1GB.
Are you serious? 36 tracks with 1.6? Okay, I guess I'll go for that MBOX Mini. Have any of you had any problems using old plug ins on Newer versions of PTLE? For example, I have Autotune 3. It works fine in 6.1, but Digidesign recommends upgrading to version 5 for PT7. I can't believe you were able to get that many tracks out of PTLE with a 1.6 Centrino.
This being the case, what's the hype of Dual Core and Quad machines? Is it just the larger amount of plug ins they could use with that power?
Second hand original Mbox vs new Mbox 2 Mini | east | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-09-2012 04:31 PM |
Please compare original mbox to mbox mini... | mbart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-22-2009 12:04 PM |
New Mbox 2 Pro 7.4 install - dead - 7.1 was fine with original Mbox - HELP! | gbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-25-2008 06:18 PM |
intel mac mini with original mbox? | hoganguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-27-2007 11:56 PM |
original Mbox vs. Mbox mini | jojo wuzaman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-25-2007 07:17 PM |
