  #21
Old 07-01-2022, 04:08 PM
huzzam huzzam is offline
Default Re: Pro tools 2022.6 released
Originally Posted by Eric Lambert View Post
As I understand it, there are ways to structure plugins under a Native DAW such that the M1 plugs operate natively while the non-native plugs do not. I don't believe it's a case of the entire plugin folder being dumbed-down to the architecture of the weakest link.
Yes that's how Ableton (11.1+) works with AU plugins on Silicon. It should be noted, though, that this works due to a compatibility layer from Apple, specific to the Audio Units format. You can have a mix of intel and silicon AU plugins, and Ableton will use whatever's best/available. The downside is that you then end up with a bunch of instances of Rosetta—one for each intel plugin—and it can end up being more cpu-intensive than just running the whole DAW in Rosetta mode.
VST & VST3 plugins do not have this capability, so silicon-native Ableton can only run silicon-native VST/VST3 plugins.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
  #22
Old 07-02-2022, 02:26 AM
djani djani is offline
https://www.mediafire.com/view/xxnp1...24.17.png/file
And it seems they've broke a custom shortcuts for the MacOS. The ones we make trough a System Preferences Keyboard tab. No way I can call a AudioSuite Gain plugin at a press of a button for example... And no internal Pro Tools option to do that.
Pro Tools Ultimate 2022.10
Mac Studio M1 Max 32GB RAM 2TB SSD
MacOS Monterey 12.6.1
RME DigiFace USB
Apogee Rosetta 200
  #23
Old 07-02-2022, 03:04 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Default Re: Pro tools 2022.6 released--selection of midi notes disabled after quantize
Originally Posted by bashville View Post
in the MIDI editor window--selected and quantized a couple bars of a pattern. After that, the events that were quantized could not be selected/moved. I can hear velocities being adjusted using the velocity trim, but the graphics for the notes don't move. So no note trimming, moving the note, any further editing after the quantize operation. See attached screen grab after using the i-beam to select a range of time. Selecting the notes to the left worked fine (they had not been quantized)--notes to the right had been quantized, and are not selected in the i-beam sweep. Long time PT user--not sure if some preference has been changed that I missed.
no problems here, I can quantize and move notes, change velocity... everything works as it should
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
  #24
Old 07-02-2022, 03:12 AM
tonwurm's Avatar
Originally Posted by Dizzi45Z View Post
I am having the same problem and even worse, if you quantize multiple times, it duplicates the notes to the new position. But yeah, after a quantize or two (with the new or old methods) you can not move or select the notes.
Too bad. I was liking the list of bug fixes, but this new bug is a deal breaker for me. I'll be sticking to 2022.5 for now.
tried it several times, no problems here.., maybe it will occur later or in other projects !?
Ultimate HDX
  #25
Old 07-02-2022, 06:19 AM
Fidelis Fidelis is offline
Oh no, I still use that for gain plugin. But I can change it to soundflow… I’ll try that before upgrading.
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
  #26
Old 07-02-2022, 12:26 PM
nednednerb's Avatar
nednednerb nednednerb is offline
1. Make a blank session/ load your given session template.
2. Make new Window Configuration of default view. Set it to config (1).
3. Open a Gain Audiosuite plugin. (and a normalize, and a meter, etc..)
4. Make new Window Config of this view. Set it to config (2), etc...
5. Save a new Session Template.
Now, when you create a new session, use your template and ALWAYS access config (2) via ". 2 *" on a numpad.
This is the preferred built in way recall window configs in later/new sessions (an open Gain plug-in, etc...)
However, I can relate to you wanting your existing method to just work the same way. I never used System Pref's keyboard shortcuts. What happens when you do the old shortcut? If a new default MacOS action is triggered, maybe you can change the default to another key combo, and PT will listen to the old command again.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
  #27
Old 07-03-2022, 02:40 AM
thin ice thin ice is offline
This is pretty annoying, as I have built up loads of these short cuts for common plugins and the colour palette.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
  #28
Old 07-04-2022, 11:28 AM
This could help as a workaround, thank you. When I use old System Preferences Keyvoard Shorcuts command nothing happens, PT completely ignores it it seems.
RME DigiFace USB
Apogee Rosetta 200
  #29
Old 07-04-2022, 06:54 PM
Jeff Schmidt Jeff Schmidt is offline
Updated from 2021.10 and it was the smoothest Pro Tools update I've had in recent memory. No hangs, corrupted prefs, or other issues that have plagued previous updates.
Loving the new Atmos Bounce options - that alone will save me a ton of time.
And, I can finally kill the N key right within Pro Tools without using SoundFlow
Just wanted to share a positive experience on here for a change. :)
2019 Mac Pro 7,1
192 GB RAM
Catalina OS 10.15.7
PT Ultimate, or whatever 2022.6 is called now
HDX 2 w MTRX, Dadman
9.1.4 Dolby Atmos over Dante to external RMU
  #30
Old 07-05-2022, 07:20 AM
jlf37 jlf37 is offline
Originally Posted by mtmusic View Post
I'm also having a new and extremely annoying MIDI issue after updating to 2022.6 today that seems related. Sometimes when I double click and create a new MIDI note, I'm unable to actually select that note to click it and drag it around. I can use the trimmer tool to shorten or lengthen the note, but I can't select it with the grabber tool, and the i-beam tool just goes right over it. Is anyone else getting this?
yes.
MP3 Conversion Quality with Pro Tools 2022 x Pro Tools HD10.3.10 Alécio Costa Pro Tools 4 06-01-2022 11:58 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
EUCON 2022.4 Released EddieJones Avid S1, S3, Dock and Control App 17 05-08-2022 07:26 PM
EUCON 2022.4 Released EddieJones Avid S4/S6 0 04-29-2022 03:32 PM
Ozone 9 Advanced Version 9.12 released April 8, 2022 gives AAX Plug-ins 0 04-10-2022 02:27 PM
