Old 10-30-2016, 09:10 AM
dental-floss-tycoon dental-floss-tycoon is offline
Default need help updating mbox2 firmware to v1.43
I need to update my Mbox 2 firmware from v1.38 to 1.43 to make it compatible with linux drivers.
I am running the updater from here: http://secure.digidesign.com/service...rticleId=24364 in "XP compatibility mode" via Windows 7 but continue to get the error: "Firmware update failed. Failed to download firmware."
Am I doing this wrong? Is the update no longer supported? Is there any other way to update the firmware on my Mbox2?
Thanks for the help!
Old 10-31-2016, 08:31 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: need help updating mbox2 firmware to v1.43
Have you tried installing the latest drivers for the Mbox 2? I thought the firmware updates where built into them, but I may be wrong.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 10-31-2016, 09:28 AM
It works with the Win XP drivers and Pro Tools LE for Win XP, and it works with the "Mbox_2_USB_Family_v90265_Drivers_70922.zip" installed on my Windows 7 machine. But none of the drivers have changed the firmware on the Mbox2, and I need the 1.43 firmware update for Linux compatibility. Do newer versions of Pro Tools update the firmware automatically?
Old 10-31-2016, 11:38 AM
JoelG's Avatar
Pro Tools only includes the HD driver, nothing for the Mbox line.
Joel
Jam Space:
Home:
Rig:
Old 11-10-2016, 10:07 PM
I'm still looking for a way to make this update work.
0.1 Bitcoin bounty if anyone can figure it out.
Old 11-11-2016, 05:05 AM
Monroy's Avatar
Monroy Monroy is offline
Linux 16.04 is compatibile with Mbox2 and working fine. I have Ubuntu Mate 16.04.
But I would like to update Mbox2 firmware to 1.43 and I have exactly the same problem with error message. Looks like digidesign/avid server stop holding this firmware.
Old 11-11-2016, 07:28 AM
so firmware version 1.38 is working with Ubuntu 16.04 for you?
When I plug the Mbox2 in and select it as Audacity's recording device in Ubuntu 16.04, I get a sample rate error if I hit record. Maybe a fresh install with MATE will help. Thanks for the info.
Old 11-11-2016, 08:33 AM
Monroy's Avatar
Yes, you're right. I installed Adacity and is sample rate error while recording. But audio for youtube, movies and music working fine.
Old 08-18-2017, 01:39 AM
square_eyes square_eyes is offline
I'm stuck on this. I'm trying to use my Mbox 2 Micro as a soundcard on my Pi.
Linux Jesse recognises the device on asla but no sound comes out. It lights up and give an encouraging squelch like it used to indicating it's being driven. But I have nothing
I can't even remember the firmware I have on it. I'd like to get some help on testing it on linux. Somone here said even on 1.38 the sound output works (that's all I need).
Edit: I was able to get the firmware updater on my Win 10 machine and it told me I already had the correct firmware. Incidentally I tried to update anyway and ran in to the same problem as OP.
Still begs the question, why isn't audio coming out of the M Box 2 Micro from the Pi? It works fine on my Windows machine.
Old 05-08-2020, 11:27 PM
stranded linux user stranded linux user is offline
Hi. This post features prominently in google for people looking to upgrade their MBox 2 to a version that works in Linux. 1.38 is sufficient for this purpose with kernels 5.0.0 and above. Which is good, because the 1.43 firmware updater just doesn't work, regardless of how you execute it.
Kudos to Avid for keeping old binaries around, and allowing me to get my old MBox 2 from the 1.1 series up to 1.38 and keep it out of the landfill.
Some one else had the same problem:
https://gist.github.com/vectorsigma/...ef6c9c2686797b
D-Command firmware updating [email protected] ICON & C|24 3 12-13-2014 03:26 AM
Updating firmware time_ghost Pro Tools HDX & HD Native Systems (Mac) 4 12-30-2013 02:04 AM
11R updating Firmware Windows 7 jrockbridge Eleven Rack 8 09-06-2011 06:48 PM
Firmware not updating cjbeckius 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-15-2006 11:47 PM
firmware updating stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-19-2004 03:01 AM
