Switching between Dyn/EQ plugins on same channel? Hardware inserts?
In Channel Mode, how do you switch between multiple Dyn/EQ plugins on the same channel?
E.g. two compressors: - Avid Pro Compressor - Waves API 2500 What I observe: - In the PT GUI, clicking on the insert slots switches to the selected plugin: OK! - When both plugin windows are open for visual feedback, it's not enough to click the plugin window handle: You have to click 'somewhere' inside the plugin's GUI. The Pro Compressor gets enabled as soon as you click anywhere in the dark grey plugin header or any of the controls. The Waves gets enabled when you click in the grey area, but doesn't respond anywhere else in its GUI, not even when changing a control. - On the App, selecting the other compressor from the Insert section doesn't change what the Dyn section is displaying. How can I switch between compressors without touching my mouse? - Maybe a nice usability enhancement would be to be able to hold Shift on the Dock and press the Dyn section to toggle between multiple inserts of the same type? Additionally: The App doesn't deal well with external inserts. Very cumbersome to enable/disable them. Much faster with the mouse. E.g. when you want to A/B listen with/without the external processing. Would be great if they could take a look at this! |
Re: Switching between Dyn/EQ plugins on same channel? Hardware inserts?
Filed to Avid support, case 03843264.
No channel Inserts??? | solomon_love | Pro Tools 12 | 2 | 02-18-2017 11:53 PM |
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
can`t load plugins and hardware inserts. need help | musicmixer04 | Pro Tools TDM Systems (Win) | 0 | 05-11-2009 01:20 PM |
bypass all channel inserts at once | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-31-2008 09:56 AM |
How Many Inserts per channel Allowed? | musicsup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-22-2005 01:28 PM |
