Old 10-28-2019, 01:19 PM
james8oasis james8oasis is offline
Default How to create an ascending note in MIDI of 2 Octaves?
Hi, I'm trying to create a single note in MIDI that spans 1-2 octaves. It seems I can only do about 2 tones. Can you help?
Thanks!
Old 10-28-2019, 03:21 PM
amagras amagras is offline
Default Re: How to create an ascending note in MIDI of 2 Octaves?
Go to the the pitch bend settings on the VI you are using and set it to 2 octaves. Draw a line in the corresponding automation lane.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 10-28-2019, 05:14 PM
Thanks for your reply. Where in the settings do I do that? When I choose pitch bend on the instrument track I only have a range of like 2 tones. If you want o email me a screen shot or anything, you can also email me at [email protected]. I appreciate it!
Old 10-29-2019, 05:22 AM
It's not in PT settings but in each vi you're using. And to find that out you have to actually read the manual that comes with the vi. That's if you want to do it by way of pitch bend.
You could always use a series of notes increasing in pitch.
A lot depends on how smooth you want the pitch change to be. Pitch bend by way of a MIDI message will give you a smooth change and separate notes will give you stair-stepped notes.
Jack
QAPLA!
Old 10-29-2019, 06:46 AM
This ^^^, just open the instrument you are using on that track, see if there's any settings icon or button, find the range of the pitch bend wheel and change it to 2 octaves, that will change it in Pro Tools too. The easiest way is to read the manual and find how to do it as it is different for every plugin.
amagrasmusic.com
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
Midi Problem - Notes being recorded in 2 octaves Zoeski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-08-2010 04:17 PM
'Create Click Track', can it play the same note? luris Pro Tools TDM Systems (Mac) 4 05-07-2008 05:03 AM
EXPORT MIDI from Stryke NOTE FOR NOTE... riggi Virtual Instruments 1 03-10-2008 07:32 PM
