Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
Old 05-09-2019, 05:05 PM
mattrixx mattrixx is offline
Default Eucon 19.5 update erased my custom soft keys
The Eucon 19.5 update erased all of my custom soft keys... WTF??
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
Old 05-09-2019, 05:18 PM
BScout BScout is offline
Default Re: Eucon 19.5 update erased my custom soft keys
Probably not. I checked and the new version of Pro Tools calls a new Pro Tools appset softkeys: "Pro Tools 19Mac.xml"
Your custom are still named under 2018 as "Pro Tools 18Mac.xml"
So Eucon isn't pulling up your version since it sees it as a version mis-match to the application in focus. Just go to:
[system drive]\Library\Application Support\Euphonix\UserSets\MC_USER_SET_Root\
In that folder, then duplicate your "Pro Tools 18Mac.xml" and rename the copy "Pro Tools 19Mac.xml". (duplicate to preserve your current -- you could just rename the original if you think that's safe but I like safeties in case I have to go back to an older Pro Tools)
Then click away to a different application so it has focus (if you have Eucon locked to Pro Tools, you'll have to unlock) like Finder and then click back to Pro Tools and it should pull your set back in since now the versions match.
The ones that Eucon updates as "factory" are kept separate in the "DYN_APPSETS" folder (one folder structure up) so there is no chance of copying over a user's set.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 05-09-2019, 05:37 PM
Thank you so much!! Worked a treat!!
Matt McKenzie-Smith
mattrixx.net
Old 05-10-2019, 08:41 AM
EddieJones's Avatar
or just load them from within EuControl Softkey editor.
Old 05-10-2019, 09:20 AM
docric docric is offline
That wouldn't work with my previous appset... tried multiple times... each time received an "incompatible appset" flag.
Following BScout's advice worked.
Once renamed & saved, then it allows re-load w/o probs.
-C' ya'
Rick
MacPro 6,1; 12 core; 64 Gb RAM; 1 TB Samsung 970 Pro w/ adapter & heatsink; OSX 10.14.5
PT 2019.6.0 Ult.
Burl MS / PT Dock/ Eucon 19.5.1/iPad Air2/ iOS 12.3.1/ProTools|Control
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Pro Tools | S3 0 04-18-2017 10:09 AM
Share your custom Soft Keys page! reichman Pro Tools | Dock 0 10-19-2016 12:26 PM
Where to recall layouts and custom soft keys? Fish Horse Pro Tools | S3 4 02-05-2016 05:54 AM
Eucon 3/1 erased my presets:( garnoil Artist Series 9 10-17-2013 06:23 AM
Tips for moving custom user sets/soft keys to a new computer? mrsquid Artist Series 1 04-04-2013 02:37 PM
