Pro Tools 11 and Mackie HUI
First post on here, apologies if it's in the wrong section. Going through older inventory here at the studio, and stumbled on to an old Mackie HUI (Firmware version 1.45). I know that HUI protocol is supported (not tested) in PT 11, but is anyone actually using the original hardware? We have a ProControl and Fader Pack (which of course doesn't work in 11), but figured we might use this for the mobile rig if it actually works. If you're actually using a HUI with PT 11, what settings did you have to change? Was there a need for additional driver d/l? Or updating beyond 1.45? (information on the subject wasn't easy to find...the manual references OMS...). I had partial success, but it kept dropping communication with the HUI. Anyway, thanks for any help!
Re: Pro Tools 11 and Mackie HUI
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
I use an original Mackie HUI. No problems with PT11 as it supports the HUI protocol. The great thing about the HUI is that it was built for Pro Tools and includes lots of the short cuts as physical buttons. No drivers are needed. Just connect your midi I/O and make the HUI selection and midi selections in the peripherals menu. Firmware version 1.45 is the correct one.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
Mackie HUI not working with pro tools properly
I have just acquired this Mackie Human User Interface and I am trying to use it to run my Grace M101 preamp through. I am unable to get either mic channel to work at all, directly in to the Mackie, or through my Grace. Any help would be greatly appreciated, thank you kindly,
Austin |
I AM RUNNING PRO TOOLS 12 OFF OF A MAC BOOK PRO RETINA FROM 2013 Processor 2.6 GHz Intel Core i5 Memory 8 GB 1600 MHz DDR3 Software OS X 10.9.5 (13F1077) My main issue is that I cannot figure out how to patch the grace into the Mackie. My computer is using the built in microphone. |
The HUI is not an audio interface, it is just a comprehensive midi control surface that also provides built in mic pres for added functionality. You still have to connect the audio outputs on the HUI to Pro Tools via an interface.
So then is it possible to use the first channel of the HUI as a preamp for my Rode NT1-A? Thank you for your help
You may find these useful.
The Mackie HUI manual http://www.mackie.com/pdf/hui_om.pdf and the Pro Tools guide chapter 3 http://akmedia.digidesign.com/suppor...uide_25939.pdf I know this is for an earlier version of PT, but the instructions apply to PT 11 as well. I suspect that the Grace Pre is much better than the Mackie one. Remember the HUI is technology from the middle 1990s.
Having just looked at the Grace 101, it is definitely much better than the Mackie ones. So, just to clarify, use the Grace 101, and connect it to your computer using an audio interface. The HUI does not pass audio to your computer, only midi.
Mackie C4 & Pro Tools | ctyelvis | Pro Tools TDM Systems (Mac) | 0 | 09-03-2009 05:03 AM |
Mackie D8B and Pro Tools LE 7.4 | indoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-18-2007 09:51 AM |
Mackie HDR to Pro Tools? | nicoli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-10-2005 08:49 AM |
Mackie DB8 & Pro Tools | Stuart W | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-16-2003 08:21 AM |
We are getting a Mackie d8B for Pro Tools... | dBHEAD | Tips & Tricks | 2 | 01-11-2001 01:14 PM |
