SFX licensing
I need clarification here, as this is outside my usual broadcast/film experience.
I have been approached to design the audio for an app - how frightfully current and trendy of me indeed. What is the situation with respect to licensing of commercial sfx libs? Am I able to use them as source audio, if I blend/process and recreate new audio? Or must I record my own source audio to maintain royalty free audio for the app developer? Any words of wisdom greatly appreciated cheers
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Re: SFX licensing
Check with the libraries themselves. I don't think you'll have any problems using them but why not make certain?
Here is Sound Ideas end user license (for purchasers obviously). Sounds like a "custom license" might be required, depending on what you have in mind and how strict they want to be. http://www.sound-ideas.com/licenses.html |
Re: SFX licensing
+1 to Postman's suggestion that you check the licenses of individual libraries and developers.
It all hinges on the kind of 'derivative works' that a developer allows. For example, users of the libraries I've made aren't allowed to redistribute the sounds as individual sounds (this is normal, obviously). However, users can incorporate them in a derivative work, and even though the sounds may be relatively exposed, they are there as part of the creative work, e.g. a single sound that punctuates action in a movie, game or whatnot. Where it gets murky is when the sound does appear 'as a sound', e.g. if it were in an app that allows the user to trigger and manipulate the included sound effects, as part of the interface interaction or a music sequencer. In those cases, it would be worth asking a developer directly in advance. They would probably allow it, but under a more expensive license. I hope this helps. |
Licensing? | chip88 | Pro Tools 9 | 1 | 11-08-2012 09:40 AM |
iLok Licensing | ACM Production Admin | General Discussion | 10 | 10-04-2012 04:42 AM |
Volume Licensing? | gary_bagelman | Pro Tools 10 | 2 | 11-10-2011 12:07 PM |
m-powered licensing | pixeltarian | Pro Tools M-Powered (Win) | 1 | 04-22-2011 08:44 PM |
Licensing Plugins help? | nemisis63 | General Discussion | 1 | 10-25-2002 02:58 PM |
