Old 07-09-2020, 05:47 AM
russ_signum russ_signum is offline
Default Signum Audio Release BUTE Limiter 2
EDINBURGH, Scotland, July 1st 2020*Scottish developers Signum Audio are proud to announce the release of BUTE Limiter 2, a major upgrade and redesign of the widely celebrated BUTE Limiter.
BUTE Limiter 2 delivers “high fidelity, ultra-transparent true peak brickwall limiting with a streamlined and sleek user interface”
Video Overview:
https://www.youtube.com/watch?v=AKvj1Dy1hqo
https://i.imgur.com/hDCQ9tw.png
Ultra-Transparent Limiting
BUTE Limiter 2 is driven by Signum Audio's novel limiting algorithm which is specifically designed for utmost transparency. For version 2 the algorithm has been further refined to deliver even better performance at extreme settings. Improvements to the algorithm include better bass response and support for shorter release times.
BUTE Limiter 2 features advanced adaptive auto release. The optimal release is calculated by analysing the audio input and dynamically adapting the release time. The auto release length can still be configured to fit different types of audio best, similar to traditional limiter release settings, but sounding much more natural than a fixed release length.**
As a result, BUTE Limiter 2 delivers smooth and ultra-transparent limiting that keeps the character of your master while taking care of any inter-sample peaks.
Comprehensive yet flexible UI
Whether you’re looking for an in depth analysis of your master or a compact readout - BUTE Limiter 2 can do it all.
https://i.imgur.com/eaBxqzY.png
BUTE Limiter 2 Features a resizable history view which lets you interactively examine true peak, gain reduction, threshold and output readings - you can choose to see an overview of your whole master or zoom in to a particular part. If any true peak overshoots are introduced via the post gain functionality, BUTE Limiter 2 will flag them prominently in the history with warnings. The history also supports re-metering via automatic DAW sync and will get updated if you change your limiter settings so you can see how your new settings affect your audio.
https://i.imgur.com/viwL1Uh.png
BUTE Limiter 2 also offers a meter bar view and for those with limited screen estate a very compact readout view.
Support for multiple workflows
https://i.imgur.com/QnxQ8Aw.png
BUTE Limiter 2 includes a Pre Gain to push or reduce the incoming signal’s volume before Limiting as well as Post Gain that will be applied after limiting.
The plugin can be configured to highlight either the limiter output or the overall output, that is limiter output with applied Post Gain. So whether you like to push the limiter via Pre Gain like a maximiser, or limit your signal and then use Post Gain to make up for the change in volume - BUTE Limiter 2 provides you with a streamlined display for your workflow.
https://i.imgur.com/5SQqNbU.png
Evenmore, Post Gain is complemented with an automatic Max Target functionality that allows you to set a maximum output target that you would like to reach once the limiter hits the threshold. The BUTE Limiter 2 algorithm will make sure that you never go past this Max Target.
Free Upgrade / Pricing
The plugin will be available for free to both BUTE Limiter and BUTE Loudness Suite users.
BUTE Limiter 2 is FREE for anyone who already owns BUTE Limiter or BUTE Loudness Suite.
Signum Audio is offering 30% off for July using code: BL230JLY
Competitive enterprise options are also available for studios looking for multiple licences by contacting support@signumaudio.com.
You can learn more and download a 10-day free trial here: https://www.signumaudio.com/bute-limiter
The BUTE Limiter 2 is available as 64bit VST / AU / AAX, compatible with Mac (10.9 or higher) / Windows (8.1 or higher) and Pro Tools 12.5 or higher.
Key Features:
●**** Ultra transparent true peak limiting using Signum Audios novel overshoot proof brick wall limiting algorithm
●**** Highest quality linear phase upsampling
●**** Advanced adaptive auto release
●**** 5 Different release curves
●**** PreGain, Post-Gain and automatic Max Target functionality
●**** Three different layouts:* Resizable History View, Vertical Metering View and compact Horizontal Control View.
●**** Automatic DAW sync and re-metering to reflect adjustments.
●**** History for True Peak, True Peak Output, Threshold and Gain Reduction.
●**** Warning system for Post-Gain overshoots
●**** In depth history analysis
●**** Available in Stereo and Surround versions
●**** Compatible with Mac (10.9 or higher), Windows (8.1 or higher) and 64-bit VST / AU / AAX
●**** Surround to up to 10 Channel Atmos
About Signum Audio
Signum Audio specialise in DSP engineering, improving the latest audio technology with a focus on pioneering UX design and advanced algorithms. Our current product line focuses on loudness and limiting. We are based in Edinburgh, Scotland and founded in 2017.
Signum Audio are also proud to be one of the key sponsors for The Edinburgh Festival of Sound - http://tefos.co.uk
For any enquiries, please do not hesitate to get in touch with us at info@signumaudio.com
[IMG] code is Off
BUTE Loudness Suite & BUTE Limiter on offer russ_signum Partner Announcements 0 06-12-2019 03:22 AM
New Limiter from Signum Audio russ_signum AAX Plug-ins 2 04-03-2019 12:47 AM
Signum Audio Announce 50% Off BUTE Loudness Analyser, Normaliser and Suite. russ_signum AAX Plug-ins 0 01-21-2019 06:58 AM
Signum Audio Bute Loudness Suite Now Supports Atmos 7.1.2 russ_signum AAX Plug-ins 2 09-11-2018 03:30 AM
Signum Audio's Bute Loudness Analyser: Feedback/Suggestions russ_signum Post - Surround - Video 16 08-14-2018 05:22 AM
