Best OSX version for 12.7 on Mac Pro 5,1?
I'm going to be moving from my MBP to a 2010 Mac Pro 5,1.
8 core. 2.4GHz. 1.) what's the best OSX for running PT 12.7.?Is Sierra fine? I'm all for doing what's best for PT on this machine. 2.) it has 2GBx4 installed in it. I was thinking of adding another 2GBx4 into it from OWC. Should there be any issue with that? Thanks! Sent from my iPhone using Tapatalk
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 |
Re: Best OSX version for 12.7 on Mac Pro 5,1?
Don't forget to budget for drives to record to and host your samples. Internal drives shouldn't be that expensive. |
10.10.5
or 10.12.2 |
With RAM...
Is it OK to add 4GBx4 to the 2GBx4 that I already have in the machine for a total of 24GB, or should all the sticks be the same size? Sent from my iPhone using Tapatalk
"10.10.5" (Last Mac OS in previous coding)
or "10.12.2" (Check Compatibility of all Plug-in's, Drivers and such) Also note what video card you'll be using. SSD's , 7200rpm Hybrid drives (Not fusion drives) (Seagate SSHD, Firecuda's have been good to me)
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
You really want to have all sticks the same size. Not just that but from the same manufacturer and specs. Mixing ram sizes and specs can lead to disaster.
Thanks for the confirmation. I'll just get going with the 8GB it's got. I might actually be fine. Soon though I'll stick in 4GBx4 from OWC. That'll leave me with room for another OWC set if I feel like adding later. Sent from my iPhone using Tapatalk
I'm about to upgrade from 10.10.5 to Sierra on my 5.1 too.
In my old age, I've gotten lazier and lazier so I was wondering, is everybody still doing clean installs every major os upgrades? |
That's the ONLY way to do an operating system upgrade. Also do NOT use Migration Assassin to bring your old stuff over - do a complete clean install. There's too many thing to go wrong with an in-situ OSX upgrade or using MA. Do either of those no-nos and you'll be right back here complaining about having problems.
Yeah,..
I've been doing clean installs since Snow Leopard and I always install everything manually. Just wanted to see if the tide had changed since my last upgrade. |
Avid Nexis : différence entre la version pro et la version initiale | Gustavo Woltmann | Le Forum en Français | 2 | 01-18-2017 09:37 AM |
Pro Tools requires version 9.0.6 or later, but CFnd provides version 9.0.0 | Danishan90 | macOS | 10 | 02-10-2014 03:11 AM |
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but | Patrick H | macOS | 3 | 11-20-2012 02:46 PM |
HELP! PT10 Opening new version session in older version | Claudiu | Pro Tools 10 | 6 | 11-04-2012 03:32 PM |
Incompatible library version: CFnd provides version 7.2.0 | heshion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-24-2009 03:42 PM |
