Old 12-28-2016, 02:43 PM
abbrenner abbrenner is offline
Default Cleaning up guitar parts
Hey all, back again, this time with editing questions.
We have multiple guitar tracks on our file. It's basically 2 tracks that are doubled and a unique track per guitar player (6 tracks all together). This particular question, I am asking about a section which only one guitarist is playing (3 guitar tracks, 2 identical). On the 2 identical tracks, for some reason, some of the eighths are swung. I did a little fixing on the unique track and it's sounding great. When you play all 3 together, it's muddy as all get out (some notes are swung and some are straight).
On top of this, when I go to polyphonic->warp, only very few of the notes are reading as attacks (or whatever it's called where you get the line). Maybe 1 per measure. I've been trying to guess where all the notes are, but it's really hard, and I'm not getting it after a few hours of messing with this 30s section. Is there a better way to do this? Re-recording isn't an option, unfortunately.
Edit:
The notes should be straight eighths throughout the section, it's roughly 210 bpm.
Old 12-29-2016, 07:20 AM
EGS's Avatar
EGS EGS is offline
Default Re: Cleaning up guitar parts
Originally Posted by abbrenner View Post
...When you play all 3 together, it's muddy as all get out (some notes are swung and some are straight)...
Delete the part that is causing the conflict/mud. If that now diminishes the layering too much, copy a chunk from the good track and paste to the bad track, and then shift in time a bit and/or pan differently. Hope this helps!!!
Click for audio/video demo
Click for resume
Old 12-29-2016, 08:53 AM
amagras amagras is offline
Nothing replace a good performance to start with but if you have no other choice then elastic audio should be the last thing to try on guitars, as @EGS said copy and replace from a segment with better performance, and as a last resource, analysis mode of elastic audio offers the option to write down or move the markers to the correct spot I'm the waveform, try grabbing the markers with the mouse to move them or press home+click on an empty space to create new ones / alt+click to remove
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 02-02-2017, 03:10 AM
simon.a.billington simon.a.billington is offline
Of course, if you a desperate enough and have seemed to have exhausted all your options there are other engineering tricks you can try, even if you just automate them over the muddy areas in question
Thins like subtractive eq of the lower mids, a multiband compressor to tame those mids, enhancers, transient shapers to put some definition back in. Things like that.
C6 is often my favourite tool for jobs like this, but there are others out there.
It sucks, but many times it is what it is and you can't do much about it except try to patch it as best you can. We live in a real world where nothing is rarely ever ideal. There's always something that needs fixing or enhancing. That's why the tools exist in the first place.
No one invents a tool first and then tried to find an application for it. It just doesn't work that way.
Old 02-02-2017, 09:42 AM
Andy Gone's Avatar
Andy Gone Andy Gone is offline
Edit:
Are there any repeating parts that are ok? It seems plugins won't help here. Usually in such cases I cut everything bad and replace with good from different repetition. When you have double tracks, you have more material, so it is easier.
Old 02-03-2017, 08:34 AM
JFreak's Avatar
JFreak JFreak is offline
Yes, this is my favourite as well. Any other dynamic EQ might do the job, but with this one it is a whole lot easier (which means faster).
Janne
Old 02-13-2017, 08:56 PM
zedhed's Avatar
zedhed zedhed is offline
For future reference;
Use 'Loop Record', and do a few passes so you have material to create a composite track/s or fix bad spots. Also record a 'Dry' track for each guitar so you can Re-Amp the track/s.
There is a setting in Preferences to create new clip (or words to that effect) for each recorded pass in Loop mode.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 02-13-2017, 10:05 PM
JFreak's Avatar
While that (loop record) is effective in getting many parts recorded in little time, what I would suggest instead is manually creating playlists for each take and take the time it takes for each pass -- guaranteed better results, and later on easier to comp best parts from different takes.
Janne
FS: UK/EU – Ibanez RG2550ex, George L's, Various guitar parts! mr rhys Eleven Rack 1 06-24-2011 03:50 PM
i move some parts then parts are unmuted... montreal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 05-08-2010 05:56 AM
Committing midi parts to audio. All parts ahead of bar line sad1robot Pro Tools TDM Systems (Mac) 2 04-25-2010 01:09 AM
Parts playing over each other? (and guitar tracks) silas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 07-02-2004 06:15 AM
Duplicating Guitar parts PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-18-2003 02:11 PM
