#21
Loud clicks when starting or stopping playback
Thank you so much, things like this just confuse the hell out of me when reading manuals C-State and turbo boost I've seen that in my bios before but what the hell are these
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
#22
Re: Loud clicks when starting or stopping playback
Turbo Boost increases the frequency that the CPU operates at when additional processing power is needed. Disable it for Pro Tools, which prefers a nice stable frequency.
C-States are power saving features. Disable for Pro Tools, same reason as above.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
#23
Thank you again, very much appreciated all this info Sent from my iPhone using Tapatalk
Raoul Crane
#24
http://avid.force.com/pkb/articles/e...#disable_turbo "Turbo Boost and C-State Transition affect the way the clock speed of the processor is managed. When either of these are enabled, the processor will dynamically change speeds depending on computing activity, and this throttling will generally cause errors in Pro Tools. You will need to access your computer's BIOS setup to change these settings." |
#25
As tnipe says, it sounds like you need to re-visit the optimization guide. It took me several passes through it to get everything done correctly, and I (kind of) know what I am doing.
#26
Yeah I've been through it many times, but things I'm not sure about I dare not touch
Raoul Crane
#27
See if there's anything that can help in this thread:
http://duc.avid.com/showthread.php?t=377580 Cheers,
#28
Ok guys here are some pics of CPU-Z and my bios setting I haven't a clue what most of these setting are or do maybe something here is set wrong
Raoul Crane
#29
http://www.sweetwater.com/sweetcare/...for-windows-7/ |
#30
Thanks Tnipe I disabled that the other strange thing I encounted if I disable hyper threading in BIOS when pro tools loads and it gets to the part creating DAE it freezes the PC so I have to have that on in the BIOS
Raoul Crane
Edit window keeps jumping to bar 45 when starting/stopping transport | DJ Hellfire | Pro Tools 12 | 0 | 01-16-2016 05:07 PM |
Starting and Stopping Pro Tools from Venue | Scott Fahy | VENUE Live Sound Systems | 4 | 02-14-2012 12:43 PM |
Cannot control starting and stopping of cursor | skydogsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-03-2008 02:40 AM |
Loud Pops at edits(punch points), starting and stopping play | dw_deej | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-10-2007 03:57 PM |
display starting and stopping | murdock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-13-2000 09:40 PM |
