Old 05-07-2013, 01:02 PM
rantanplan rantanplan is offline
Default How to reset volume automation of a segment to 0dB
Hi there
Is there an easy way to set the volume automation of one audio segment to 0dB (reset)?
Just deleting all breakpoints in a segment doesn't always work. Sometimes there are breakpoints next to the the segment border. In this case, i get a ramp, or i have to adjust the border breakpoints manually...
Or maybe this is just an editing/operation setup option?
Cheers
Old 05-07-2013, 04:06 PM
abblabla abblabla is offline
Default Re: How to reset volume automation of a segment to 0dB
Hi
select segment, alt clic fader, then automation write to current: command / (numeric keyboard)
abblabla
Old 05-08-2013, 06:49 AM
Stig Eliassen's Avatar
"Write to" commands are HD or CPT only.
I've only worked without HD features on my mobile rig for a little while, so there's probably a better way, but one way is to:
  • put track into Write auto mode
  • make selection
  • Option+click fader to make it jump to unity
  • start playback
  • stop, and select a piece of the newly recorded automation
  • copy
  • re-select the clip/part you want to set at unity
  • Option+Command+V to paste to fill the copied volume automation to the entire selection
  • follow up with an optional Backspace to delete "surplus" breakpoints
STRUCTURE FREE Volume+Pan-Reset on pushing SPACE VRW Virtual Instruments 1 05-27-2013 08:18 PM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
How to reset all automation data? focusonsound Windows 5 06-30-2011 10:50 AM
track automation reset ? basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-10-2009 09:01 PM
Can I easily reset an entire track's volume to zero? yin7yang64 Tips & Tricks 3 03-07-2002 09:09 PM
