PT 10.3 Freezes When "Restoring Audio Playlists"
Hi all
I'm having a very particular problem with since upgrading to PT 10. I'm trying to load a session created in PT 7. The session loads right up until Pro Tools is "Restore Audio Playlists" at which it freezes every-time, across multiple sessions (all PT7). I have no issues opening PT 9 or PT 10 sessions recording/mixing. Things I have tried to no avail: - Create a PT 10 session and import session data. I've tried importing just one track, copy sessions data, unchecked "import alternate playlists" as well as "do not import playlists". Still freezes. - Trashing PT 10 preferences. Doesn't help. - Upgraded from PT 10.3 to 10.3.1 - Creating a new windows User login just for PT. The only thing I haven't yet tried is rolling back to PT 9 and trying from there. I'm running off W7 X64 and a 003 Rack. Suggestions appreciated. SiSoftware Sandra Computer Model : Gigabyte Z68X-UD4-B3 Processor Model : Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Speed : 3.5GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte Z68X-UD4-B3 BIOS : Award (Phoenix) F5 04/11/2011 Bus(es) : X-Bus PCI PCIe USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : No Total Memory : 8GB DIMM DDR3 Chipset Model : Intel Sandy Bridge DRAM Controller Front Side Bus Speed : 1x 100MHz (100MHz) Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : Kingston 9905403-400A00LF 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston 9905403-400A00LF 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : NVIDIA GeForce GTX 560 Ti (256 SM5.0 1.7GHz, 1GB, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce GTX 560 Ti (256SP 8C 1.7GHz, 1023.7MB) CUDA Processor : NVIDIA GeForce GTX 560 Ti (256SP 8C 1.7GHz, 1023.7MB) Compute Shader Processor : NVIDIA GeForce GTX 560 Ti (256SP 1.7GHz, 978.4MB) Storage Devices WDC WD7500AALX-009BA0 (750.2GB, SATA600, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (E:) C300-MTFDDAC064MAG 64GB (SATA600, 2.5", SSD, NCQ) : 60GB (C:) KINGSTON SSDNOW 30GB (30GB, SATA300, 2.5", SSD) : 28GB (D:) WDC WD7501AALS-00J7B1 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (G:) Generic USB SD Reader (USB) : N/A (H:) Generic USB CF Reader (USB) : N/A (I:) Generic USB SM Reader (USB) : N/A (J:) Generic USB MS Reader (USB) : N/A (K:) Optiarc DVD RW AD-7260S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices System Reserved : 100MB (NTFS) Hard Disk (C:) : 60GB (NTFS) @ C300-MTFDDAC064MAG 64GB (SATA600, 2.5", SSD, NCQ) Hard Disk (D:) : 28GB (NTFS) @ KINGSTON SSDNOW 30GB (30GB, SATA300, 2.5", SSD) Hard Disk (G:) : 699GB (NTFS) @ WDC WD7501AALS-00J7B1 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Hard Disk (E:) : 699GB (NTFS) @ WDC WD7500AALX-009BA0 (750.2GB, SATA600, 3.5", 7200rpm, NCQ, 32MB Cache) Removable Drive (H:) : N/A @ Generic USB SD Reader (USB) Removable Drive (I:) : N/A @ Generic USB CF Reader (USB) Removable Drive (J:) : N/A @ Generic USB SM Reader (USB) Removable Drive (K:) : N/A @ Generic USB MS Reader (USB) Optical Drive (F:) : N/A @ Optiarc DVD RW AD-7260S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte Cougar Point LPC Controller LPC Legacy Controller 1 : T2 87-28 Audio Device : Giga-Byte Cougar Point High Definition Audio Controller Audio Device : EVGA 0E0Ch Audio Codec : nVidia 0016h Audio Codec : nVidia 0016h Audio Codec : nVidia 0016h Serial Port(s) : 1 Disk Controller : Giga-Byte Cougar Point 4 port SATA IDE Controller Disk Controller : Giga-Byte Cougar Point 2 port SATA IDE Controller Disk Controller : Giga-Byte 917Ah Disk Controller : Giga-Byte 917Ah USB Controller 1 : Giga-Byte Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Giga-Byte Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Giga-Byte 7023h USB Controller 4 : Giga-Byte 7023h FireWire/1394 Controller 1 : Giga-Byte VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Brother HL-2270DW series (1200x1200) Peripherals Media Player : () Media Player : () Media Player : () Media Player : () Network Services Wireless Adapter 1 : Rosewill RNX-N150PC Wireless LAN Card (802.11g (ERP), AES-CCMP, 72Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 7.2 |
Re: PT 10.3 Freezes When "Restoring Audio Playlists"
Any ideas at all? I've made no progress.
Hello ... find a solution? I have the same problem with a 2 hour session, I imported channels one by one ... but the problem persists with BD and SN channels.
I am unfortunately having this issue as well. I would very much like to get some sort of answers as I am truly stuck with lots of sessions to complete. Please somebody HELP!!! |
The same here.. I can't open session saved two months ago also on PT10 ?! It happend after I reinstalled Windows 7..It locks session stored on my audio drives..When opening this session from backup disc it works ?!
Musician,Producer etc.. PT|HD Ultimate Native , UAD-2 Octo x2 , Win 10 Pro 64 bit, AMD ThreadRipper 3960X (24 cores 3,7Ghz (48 threads), 64 GB G.Tech DDR4 3200MHZ ,Gigabyte TRX40 Designare (with Thunderbolt), (Philips 40'LED screan) , Samsung 24" LED 2x192 I/O, Nuendo 4.3, Wavelab 6, Halion 3.5, Yamaha 02R96V2, AvalonAD2022, AvalonVt737sp etc... www.MrPollack.pl ,www.facebook.com/polak.bros.studio |
Anyone find a solution to this?
Hi there
I am a new member. It is an old threat, but I have the same problem. I need to transfer a couple of protools 7 sessions to protools 10.3.8 for mixing/mastering. Has someone found the solution? Thanks a lot! Friendly greetings Jan |
AVID !!! HELP !!! I'm stuck with my sessions ,please !!!
When I installed PT11HD Demo it opens my problematic sessions from PT10HD..WTH ???!!!
I had the same issue. This happen when my computer updated to windows 10 and the plugins needed the preferences set again when loading Protools for the first time. The problem occurred when the the Waves Bundle plug-in preferences were changed from what they were before. For example the Waves Bundle preferences asked to select "Don't use TDM plug-ins" "Don't use HTDM plug-ins" etc. After the Windows 10 update i changed the preferences from they were first time i installed the Waves bundle and all the old sections froze on "Restoring Audio Playlists" and all new sections opened fine.
After changing the Wave Bundle preferences back to what they were before when i first installed it, all old sections worked fine, hope this helps |
Pro Tools 10 HD freezes at "Restoring Controllers....Configuring EUCON" | Mr. Light | Artist Series | 1 | 02-25-2016 10:42 AM |
Pro Tools Crashes during "Restoring Tracks" portion of startup | rhythmator | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 12-28-2014 10:42 AM |
Pro Tools freezes - "restoring audio playlists" | aldersyde | Pro Tools 10 | 6 | 05-13-2014 03:40 PM |
Profire 610 + PT9.0.5 on HP DV7 Win7+64 "Crash" at Restoring Audio Settings **HELP** | ozbirko | Windows | 2 | 09-14-2011 12:23 AM |
Session keeps freezing on opening when it is "Restoring Audio Engine Settings" | bradykrzemien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-18-2009 09:18 AM |
