Old 08-04-2012, 02:39 PM
Markownage Markownage is offline
Default Eleven Rack no output HELP US!
i have just installed Pro tools 10 and have used the last 10 hours to get it working, and so far we have gotten a very little closer to start recording, but now we stumpeled upon a strange problem.
i have a Eleven Rack installed and all drivers are running perfectly, but when i make a new track there is no output to choose.
HELP! whats the solution for this madness?!
Old 08-04-2012, 03:40 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack no output HELP US!
Default the IO. For some reason when you choose the basic template for IO (ElevenRack) when you create your session, the settings don't actually match. So just do a default.
http://www.youtube.com/watch?v=-Rjk5qVFEE8
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 08-04-2012, 05:41 PM
i have done everything in pro tools that the video tells me to do, i still have no outputs
Old 08-04-2012, 06:47 PM
Benoni's Avatar
Did you set the out for the track AFTER defaulting the IO?
What did you set the Input to? Should be "ElevenRig L/R"
What kind of track are you using? Should be a mono or stereo AUDIO track (or Aux track if you just want to hear the rig)
If you are using an AUDIO track did you ARM the track?
Are you trying to play while PT is playing or stationary, is there something already on the track? Try Alt+K to cycle the input mode.
Are you trying to listen back through headphones or monitors? Where are these connected?
Is there any activity in Pro Tools, meters showing a level ect...
Is the Eleven Rack selected as your interface? Do you have other interfaces connected?
Did you turn the volume up?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Eleven Rack Output to Amp buzz antonis Eleven Rack 45 10-31-2017 06:59 AM
Eleven Rack output in live situation, Bug or what? darren051234 Eleven Rack 10 06-20-2013 04:47 AM
Eleven Rack Output to Amp dress4riot Eleven Rack 1 03-26-2013 10:59 AM
Eleven Rack Output Question Bill Denton Eleven Rack 1 09-09-2012 11:06 AM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
