Old 12-15-2016, 01:17 PM
Marsdy Marsdy is offline
Default S6 and UAD plug-ins.
Just wondering how well the UAD plug-ins map to the S6 or if they do at all?
Just picked up a 4-710d pre that came with a free UAD-2 QUAD DSP Accelerator card!
Dave Marsden
UK
Old 12-16-2016, 08:31 AM
EddieJones's Avatar
Default Re: S6 and UAD plug-ins.
They will map but not sure how they look. A lot of ex Avid people work there so maybe quite well....
Old 12-16-2016, 08:37 AM
Thanks Eddie. I'll find out soon enough. ;-)
...If they can get a card to me after a ten week wait!!!
Dave Marsden
UK
Old 12-16-2016, 08:48 AM
Drew Mazurek's Avatar
They're mostly mapped well. API Vision Strip has one omission for example.
If you find discrepancies, let me know and I will report them for you.
www.drewmazurek.com
Old 12-16-2016, 01:46 PM
Thanks Drew. Hoping to get my card next week.
To be fair to UAD, there are various third-party plug-in developers who are getting it wrong. For example, if you expand a compressor from the Dyn button, you get a different set of parameters in different places when expanding from the Inserts button on the Process Module. Both will sometimes have parameters missing altogether. Waves are often getting wrong. McDSP are doing a good job.
Dave Marsden
UK
Old 01-30-2017, 10:06 AM
creativecontrol's Avatar
Yes - please - not just UAD plug-ins. Anyone that has concerns or suggestions for pagetable improvements for any 3rd party plug-ins please report them and we will make sure the feedback gets back to the developers. Thanks!
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-14-2017, 07:05 AM
Jeff
I contacted Plugin Alliance directly re their BX Console .
They said they would correct the errors . .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 02-14-2017, 04:48 PM
EddieJones's Avatar
The EQ and DYN button layout will always be the same, this is defined in the EUCON SDK and the idea is that no matter what plugin you are using the controls are always in the same place. This does have the limited issue of only showing standard controls. The inserts use the plugin manufacturers layouts so can show everything if they desire.
Old 03-01-2017, 05:59 AM
Just out of curiosity, what were the omissions or errors in the bx_console plug-in? I just started looking at the mappings and pagetables for some of the Plugin Alliance stuff. Thanks.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-01-2017, 06:09 AM
Jeff
Hi Jeff.
The EQ when expanded, in the 3rd knob column in from the left it says “2 Mid Freq” + “1 Mid Gain”.
These are changing the BX Console channel number, which I guess is fine but it should say “channel number”.
When attentioning an instance of Console, the dynamics section knobs push/pull assignments to the S6 touch screen aren't all assigned. Plus the knobs on screen from top to bottom should match the knobs on either side of the touch screen.
Sugar Bytes, Plug & Mix and Eventide Plug Ins FS Tops3b Buy & Sell 4 01-02-2018 01:13 PM
Plug ins Missing (Kontakt, POD Farm) from Pro Tools 10 Plug-in list smythmakesmusic macOS 28 05-13-2017 04:41 AM
Plug-ins problem - Move Unauthorized Plug-ins [SOLVED] HBHH macOS 4 10-03-2013 04:26 PM
Super TDM Plug ins;TC VSS3,Master X,Line 6,Sonic Solutions,Eventide TDM Plug Ins Digitaliz Buy & Sell 3 07-26-2013 04:39 AM
Massey plug ins demo corupted mixer, 'Plug in Racks need reset' amerikiwi VENUE Live Sound Systems 2 09-21-2012 09:42 PM
