Old 05-25-2010, 04:28 PM
epu epu is offline
Default Okay, who's using an SSD for RECORDING?
Just ordered 3 new SLC SSDs to use with my new upcoming system build. All of them were from MTRON (32GB). Couple this with one extra HDD for storing samples. I would load in the samples for the VIs I need, and then save the respective MULTIS and KITS to the SSD for loading/recording a particular session. One of the SSDs will have the OS (System).
On my laptop, for which I am using a 16GB Express Card SSD (SLC, also from MTRON), a session with Heavy VI Usage (i.e. thousands of samples) and lots of AUDIO tracks and plug-ins, never takes more than 10-15 seconds to load. I never get error messages (ever!) and sessions seem to be more fluid, smooth and motivating (reminding me of working on a 90s ROM Keyboard Workstation where everything just loads instantly).
I'm wondering if the HDD is the typical cause of 90% of Pro-Tools problems on the Native Side of things. Seems like PT can never get the audio fast enough on some systems, sans my current Laptop system and older Digi 001 system (which did by coincidentally have a lot of error problems).
Macbook Pro 15" (Mid 2014)
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 05-26-2010, 09:41 AM
rqstudio rqstudio is offline
Default Re: Okay, who's using an SSD for RECORDING?
Over the past few months a few people have discussed it but they are still rather small and not very cost effective. When they get up to 500 gigs for $100 they will probably fly off the shelves.
www.rickqueststudio.com
Old 05-26-2010, 10:37 AM
mhuang mhuang is offline
It's my understanding that SSD's write rate is actually not as fast as traditional HDs, where it excels is its blazing read speed. i would proably use SSD only as sample playback drive and keep using normal HD for recording.
Old 05-26-2010, 04:18 PM
epu epu is offline
Well, my Express Card SSD posts read/write times of 100 MB/Read and 100 MB/Write respectively. Some of the PHOTOFAST cards out of Japan claim 270MB R/W speeds. I am using my Express Card SSD for sample playback/MIDI AND Audio without a hiccup. The size of the drive doesn't matter much to me, since you can move audio back and forth off of the drive.
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Recording timing / late recording issue resolved DAWgEAR Pro Tools HDX & HD Native Systems (Win) 0 07-17-2013 09:10 AM
low latency recording vs low hardware buffer size recording chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-27-2009 06:49 AM
Distortion of Recording When Playing Back Recording acs Pro Tools M-Powered (Win) 2 03-18-2008 04:29 PM
PT 5.1 - Recording very lengthy narrative project.. ran out of recording disk space? Rockman-Songwriter Pro Tools TDM Systems (Mac) 6 04-16-2003 12:32 AM
Recording automation AT THE SAME TIME as recording tracks mikeb37 Tips & Tricks 3 03-13-2000 09:43 PM
