Using an External Firewire Hard drive
Good'ay Folk,
Wondered if anyone can offer me a quick fix for my Small Problem! I have just recently purchased a digi002 Rack. My host computer is a Dual 1.42Ghz G4 and i am trying to use an external Lacie 120 Gig (firewire)as a media disk. The problem is that if i try to import Audio (onto the External Drive) it's glitchy as Hell, if I use the Internal Drive the Audio is Fine! I have hooked my system as recommended in the mannual! I have searched for similar threads! Please Help? Many Thanks in Advance.
"Open The Pod Doors HAL?" |
Re: Using an External Firewire Hard drive
Make sure you have the latest FW drivers/extensions for your Mac and that there are no other 3rd party FW drivers/extensions active or loaded.
Ideally, you originally re-formatted the Lacie drive HFS+ with the Mac utility after you fired it up. Not sure failure to do so would give you this particular problem, though. Just food for thought. Bad or cheap quality firewire cable could also be a factor. Plus what 'where' said...
Good luck, MR
Learn to listen. Listen to learn. |
External firewire hard drive | mtbass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-09-2008 01:15 AM |
External Hard Drive Firewire 400 | thekajunpimp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-13-2007 08:10 AM |
What is the best firewire external hard drive!!!! | ike805 | Storage Subsystems | 2 | 10-23-2005 02:29 AM |
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be | Fucius | General Discussion | 4 | 03-19-2002 11:26 PM |
External Firewire Hard Drive.....how about this one...... | jason66213 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 10-31-2001 12:05 AM |
