Old 07-02-2012, 09:40 PM
cristol2k cristol2k is offline
Default Adjusting automation volume by 1dB in PT 10
New to Pro Tools, I am not finding a solution to this in Pro Tools Help, the knowledge base or the DUC forums: When mixing, when I have selected the entire graphical automation volume line for one track, for the length of the song, and want to lower or raise the volume of the entire track (all breakpoints) by 1dB, the line will only move in 2dB increments no matter how slightly I move the mouse with the Trim tool. Alternatively, when I try to use the pop-up Vol fader on that track in the I/O panel, the value changes there but it doesn't seem to affect the automation gain. There must be some way to achieve a 1dB volume change? Seems like this would have been in the documentation; sorry if I missed it.
Many thanks.
PT 10.0.1
OS X 10.6.8
Old 07-02-2012, 10:22 PM
JKD99 JKD99 is offline
Default Re: Adjusting automation volume by 1dB in PT 10
Hold down Control, and/or increase the track height to give you the resolution you need....all the way to 0.1dB increments.
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 07-03-2012, 07:39 AM
Meads Meads is offline
It's not control, but command.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 07-03-2012, 09:27 AM
The Weed's Avatar
The Weed The Weed is offline
And there's no need to highlight the nodes, just go past the last automation node on the track, get the upside down rectangle, hold down Command, left click and slowly lower the track 0.1 db at a time. As long as you go past the last node on the track to do this, all the nodes will lower together.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-03-2012, 12:47 PM
Thanks Meads!
One of those things in PT I've done a thousand times without looking but can't explain it to anyone else, LOL :)
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Old 07-03-2012, 04:32 PM
albee1952 albee1952 is online now
Command on a Mac, Ctrl on a PC. That engages "fine" mode so you can make changes in .1db increments
Old 07-03-2012, 11:20 PM
Originally Posted by JKD99 View Post
Thanks Meads!
I feel you. Everytime I'm asked about a shortcut, not sitting at a keyboard that moment, makes me look like a jerk.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 07-05-2012, 10:15 PM
I was away for a couple of days but just want to thank you all for straightening me out on this. Really appreciate that! Awesome solution; good to go now.
Old 01-12-2018, 05:26 AM
bobdamit@gmail.com's Avatar
[email protected] bobdamit@gmail.com is offline
Ctrl also works to slow-drag a range of nodes. The trick is, you have to press ctrl (sorry, windows guy) after you click above the curve. If you hold ctrl before you click, it turns the tool into "insert a new node" mode. So Click, don't move, press ctrl, start moving. Works great.
Nice to see that shift does a time-constraint as well.
I'm on learning curve for multiple DAWs now coming from SONAR and filling my brain with all these nuances.
Cheers,
Old 01-12-2018, 08:22 AM
EGS's Avatar
EGS EGS is offline
Ha !!! Me too. Plus, I work on Mac and PC rigs, so I can never talk about shortcuts in any way that makes sense!!!
Click for audio/video demo
Click for resume
Adjusting volume after automation is written rock15478 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2015 05:42 AM
Adjusting Playback Volume plums 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-11-2007 09:42 AM
adjusting volume automation euphjazz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 12-29-2005 07:40 PM
adjusting region volume tokyofan General Discussion 1 07-11-2004 11:18 PM
adjusting volume coreybox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-19-2004 04:53 PM
