Old 09-15-2009, 12:35 PM
bradykrzemien bradykrzemien is offline
Question many errors- fatal errors and 9060 error. Sandra report inlcuded..
okay here we go ------ i am mainly having trouble with one session even tho i will get some of these common errors in other sessions occasionally
- i am using the digi 003 with pro tools le 7.4 ,
- these are my usual settings -
Playback engine -
H/W Buffersize - 1024
RTAS processor - 4
CPU usage limit- 95 (have tried from 80 to 95)
Disk buffer - level 4
cache - large
- i am using a usb connection for my external hardrive - (, i heard it can cause some problems)
the only problem with the usb is it wont let me save my audio files or session on the hardrive directly ,, i have to move or copy and paste them mannually after every session .... wiill a firewire connected external fix this ?????
- i am using the same plugins on other sessions that seem work fine.
- Somtimes when it freezes it will make a huge loud buzzing noise.
here is a couple of the error messages i am getting on this session ...
- Fatal Error - file platformsupport_/Atomicstructers.cpp,line:292,msg:logical memory==NULL
- and the well known 9060 error, which is only on this session .....
and there are a few more error messages i didnt write down ..
SiSoftware Sandra
Computer
Model : Acer Aspire M5100
Workgroup : WORKGROUP
Host Name : Brady-PC
User : Brady
Processor
Model : AMD Phenom(tm) 9500 Quad-Core Processor
Speed : 2.2GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size
L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size
L3 On-board Cache : 2MB, ECC, Synchronous, Write-Back, 32-way, 64 byte line size, 4 threads sharing
Computer
Mainboard : Acer F690GVM
BIOS : Phoenix Technologies, LTD R02-B1 01/08/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.25GB DIMM DDR2
Chipset
Model : Foxconn RS690 Host Bridge
Front Side Bus Speed : 1x 199MHz (199MHz)
Memory Bus Speed : 2x 100MHz (200MHz)
Chipset
Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub
Front Side Bus Speed : 2x 995MHz (2GHz)
Total Memory : 4GB DIMM DDR2
Memory Bus Speed : 2x 332MHz (664MHz)
Memory Module(s)
Memory Module : FF 1GB DIMM DDR2 PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3)
Video System
Video Adapter : NVIDIA GeForce 8600GS (16 SM4.0 1.1GHz, 512MB DDR2 2x400MHz, PCIe 1.00 x16)
Storage Devices
WDC WD5000AAJS-22YFA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache) : 466GB (C:) (D:)
ST3500830AS (500.1GB, USB/SATA300, 3.5", NCQ, 8MB Cache) : 466GB (K:)
Generic-Compact Flash (USB) : N/A (G:)
Generic-SM/xD-Picture (USB) : N/A (H:)
Generic-SD/MMC (USB) : N/A (I:)
Generic-MS/MS-Pro (USB) : N/A (J:)
KingstonDataTraveler 2.0 4GB (USB) : 4GB (F:)
HL-DT-ST DVDRAM_GSA-H60N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Logical Storage Devices
PQSERVICE : 10GB (NTFS)
ACER (C:) : 228GB (NTFS) @ WDC WD5000AAJS-22YFA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache)
DATA (D:) : 228GB (NTFS) @ WDC WD5000AAJS-22YFA0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 8MB Cache)
Optical Drive (E:) : N/A @ HL-DT-ST DVDRAM_GSA-H60N (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Removable Drive (G:) : N/A @ Generic-Compact Flash (USB)
Removable Drive (H:) : N/A @ Generic-SM/xD-Picture (USB)
Removable Drive (I:) : N/A @ Generic-SD/MMC (USB)
Removable Drive (J:) : N/A @ Generic-MS/MS-Pro (USB)
IOMEGA_HDD (K:) : 466GB (FAT32) @ ST3500830AS (500.1GB, USB/SATA300, 3.5", NCQ, 8MB Cache)
Removable Drive (F:) : 4GB (FAT32) @ KingstonDataTraveler 2.0 4GB (USB)
Peripherals
LPC Hub Controller 1 : Foxconn IXP SB600 SMBUS Controller
LPC Hub Controller 2 : Foxconn IXP SB600 PCI to LPC Bridge
LPC Legacy Controller 1 : ITE IT8718F
Audio Device : Foxconn IXP SB600 High Definition Audio Controller
Audio Codec : Realtek Semiconductor 888 High Definition Audio
Serial Port(s) : 2
Parallel Port(s) : 1
Disk Controller : Foxconn IXP SB600 Serial ATA Controller
Disk Controller : Foxconn IXP SB600 ATA Controller
USB Controller 1 : Foxconn IXP SB600 USB Controller (OHCI0)
USB Controller 2 : Foxconn IXP SB600 USB Controller (OHCI1)
USB Controller 3 : Foxconn IXP SB600 USB Controller (OHCI2)
USB Controller 4 : Foxconn IXP SB600 USB Controller (OHCI3)
USB Controller 5 : Foxconn IXP SB600 USB Controller (OHCI4)
USB Controller 6 : Foxconn IXP SB600 USB Controller (EHCI)
FireWire/1394 Controller 1 : Foxconn TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : ATI SB600 SMBus
SMBus/i2c Controller 2 : ATI AFS SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote Driver (300x300, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Peripherals
Media Player : ()
Media Player : ()
Media Player : ()
Media Player : ()
Media Player : Kingston DataTraveler 2.0 (3.72GB)
Network Services
Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows Vista Home 6.00.6000
Platform Compliance : x86
Windows Experience Index
Current System : 5.0
Performance Tips
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 09-15-2009, 12:39 PM
Default Re: many errors- fatal errors and 9060 error. Sandra report inlcuded..
Did it ever work on this machine? It appears you are recording to a USB drive? That is not recommended or supported.
Chipset
I don't have any idea if this is compatible with Pro Tools.
Old 09-15-2009, 12:49 PM
do i have to buy a new external hardrive that has the firewire already with it..... or can i buy a firewire to use with my external hardrive i already have ??
Old 09-15-2009, 12:50 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
What Albee'sure said as well as ur system drive & ram may be a bit slow on top of u actually record to a flash drive(Usb drive)... U have quite a bit of cons to be trying to run PT; & please don't say, It use to work because honestly if so, u had just been pretty lucky to say the least...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 09-15-2009, 01:22 PM
well i though a computer with 4 gigs rams and 500 gig hardrive is more enough... am i wrong??
do i need a new computer ,?? cause that was the best one futurshop had , at the time , like a year ago ..
and you didn't answer my first question .... do i have to buy a new external hardrive that has the firewire already with it..... or can i buy a firewire to use with my external hardrive i already have ??
Old 09-15-2009, 01:24 PM
That has nuthin to do with it if its not up to speed... U know what I mean?
Well after seeing ur Tamara report with that Chipset & 8mb cache drives & ram that is a bit on the slower side, I say yeah; @ least get a FW drive though, which is something u should want to have anyway & see what that does for u... & I wouldn't buy from FutureShop anymore... They should let Borat change there name to FutureShop NOTTTTTT
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 09-15-2009, 01:41 PM
TOM@METRO's Avatar
And as everyone has said... Yes, you will need a qualified firewire drive.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 09-15-2009, 01:43 PM
spkguitar's Avatar
Is the drive that you have firewire capable? Does it have a firewire connector as well as a USB connector? If not, you will need to buy a new drive.
You are also going to need a Digidesign qualified firewire interface; that is not one of them.
Also, the RSxxx chipsets have been known to be incompatible with Pro Tools.
"Fast enough" and "Has enough memory" do not equal "compatible". You dig?
Old 09-15-2009, 02:24 PM
so you mean the firewire output on my computer isn't the right one ?? or what????
so could someone show me a brand of a type of computer that is compatible and up to speed , and doesn't have the incompatible Rsxxx chipsets????? cause i don't know where to look? not futurshop apparently ... i don't even know where to start looking...??
Old 09-15-2009, 02:26 PM
THIS would be a great place to start...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
SANDRA report for DAE errors ... FMviolin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-10-2012 05:28 PM
Getting a Runtime error (Sytem log errors and Sandra report run) keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-30-2010 10:22 AM
HELP! DAE -9060 -9031 errors(sandra) ram130 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 35 06-20-2010 12:21 PM
(-6088) and other errors (Sandra report enclosed) powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 02-09-2010 07:53 PM
9073 errors - sandra report included. djgizmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-03-2010 03:26 PM
