Insert on monitoring
Hi!
I have an S10 with DAD DX32 for i/o and monitoring. In my studio I use the Sonarworks plugin to compensate for acoustic issues in my particular room, which does help a lot. To be able to listen to all sources (PT, Mac etc.) through the correction, I have set up a "detour" patch of the monitor signal through a Dante stream into the Sonarworks plugin in AULab, and back again to the physical output that drives my speakers. All is well, except for a round trip latency which prevents me from using the correction during tracking while listening in the control room. So for tracking situations, I need to physically change the signal path and monitor profile in the DAD, and then repatch when I´m done tracking. This works, but it is a but unsexy and cumbersome process.... So, on the S6 monitoring section there is a button named "Insert", which seems to be unused at the moment. I would like to be able to use this button to switch in and out a user defined insert point in the DAD monitor profile (which is practically the same software as for the MTRX, right?), so I can easily switch between corrected listening (with latency) and uncorrected listening (without latency). Can this be done? Best, Javed Kurd Oslo, Norway. |
Re: Insert on monitoring
Greetings,
That is certainly an interesting workflow that you have implemented. With regard to room tuning, we certainly want to leverage the upcoming DSP option card from DAD which is integrated directly into the DADman application and could be further implemented for more comprehensive control directly from the S6 surface. http://www.digitalaudio.dk/PRODUCTS/...ontrol-License Jeff |
Thanks for your reply!
If I understand correctly, the DSP card you are referring to will only fit in the MTRX or AX32? So that still leaves DX32 users with no implemented hardware option, as I can see? An insert point as requested would then give DX32 (and X-mon?) owners an alternative solution, whether they choose to do like me, routing through software, or through other hardware solutions like Trinnov, KRK Ergo or similar. I would think that an option to switch the insert (and the latency) on or off with a button is a very handy and functional solution for everyone using room correction? Thanks, Javed.:) |
You've created a very specific (and quite frankly -- not good) solution to your problems. It's not good for the obvious other problems you've created. If you are using DADman, you could mult your output chain into two different monitoring setups one with and one without your "insert" -- which would actually just be the receiving signal post efx. Then flip which monitor chain you want open. |
Yes, there are several hardware solutions with their own bypass switch, but they are very often stowed away in racks or out of reach to be managed easily. Being a music producer in broadcast, I know of several other systems that have this functionality implemented in the control surface (Studer and Lawo just to name a couple that springs to mind). Also, the solution you mention using DADmans Monitor Profile would mean that you have to define two separate listening chains going to the same physical output (monitors). As far as I know that is not possible to do i Monitor Profile, but maybe I have missed something...? Since you seem to have a solution, could you please share how to actually set this up? Javed. |
You set them up as two separate source chains not outputs. (I can elaborate if you'd like but I think that should get you thinking in the right direction)
(bypasses for rack gear calibration have been on GPIO triggers or other remote bypasses including software) |
Change one insert on a track - change all tracks with same insert | World Spirit | macOS | 6 | 02-22-2012 03:07 PM |
How to insert hardware as channel insert | Lqoau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-19-2012 07:29 AM |
Monitoring through Rosetta vs Monitoring through 003 | Rob0214 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-17-2010 03:02 AM |
How to insert time / insert measures, without upsetting tempo map and markers | imp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-25-2003 05:45 PM |
D-verb Insert won't insert | Julien J. Noel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-20-2002 03:37 PM |
