Input monitoring question
Hello
Since the release of PT12.1 not hd users were made input monitoring available to them. My question is when I am record enabling a track I can still hear monitored signal pass through (with latency) through pro tools even though input monitoring is NOT enabled. Is that the way it is supposed to be or is it a bug or should fix something in my pro tools settings? I am monitoring through my interface mixer (to eliminate latency) and every time I record I am forced to pull the pro tools fader all the way down. Is there a way so set up pro tools so that I will monitor the record enabled track ONLY if input monitoring is on? Thanks! |
Re: Input monitoring question
Low Latency monitoring enabled? -- if supported?(try it off and on) |
Low latency monitoring is not enabled (Since I like to monitor through my interface software mixer I never turned it on) Not sure what mode inout monitoring is on...how do I check? Thanks |
Turn Low Latency Monitoring on - that will mute tracks that are in record so you only hear through your interface software mixer. If input monitoring is off (and Auto Input Monitoring is on), you will still hear what's on the track in the lead up to a drop in. Works great!
Protools Studio 24.3, 2018 Mac Mini, Core I5 6 core, 16Gb ram, Sonoma 14.4, Focusrite Clarett+ 8pre, Focusrite Octopre. Last edited by GeoffLee; 09-01-2015 at 03:56 AM. |
http://duc.avid.com/showthread.php?t=351623 |
Turning on input monitoring on individual track is still an only HD feature? Thanks! |
Yes, Mutetone or running the DAW at a 64 sample buffer which is what I do. |
To be honest I am pretty surprised this feature doesn't exist in Pro Tools at all. I have Cubase as well (have been using that since SX3 days for over 10 years) and Cubase has that feature. But nothing beats Pro Tools automation, at least for me. |
Turn on Low Latency Monitoring - it will mute the record enabled track so you only hear your input through your interface software mixer.
Protools Studio 24.3, 2018 Mac Mini, Core I5 6 core, 16Gb ram, Sonoma 14.4, Focusrite Clarett+ 8pre, Focusrite Octopre. |
Input Monitoring Final Question | manfromspace | Pro Tools 10 | 52 | 03-17-2013 08:49 AM |
Input Monitoring Question... | alfaholic | macOS | 2 | 04-15-2012 09:40 AM |
Input Monitoring Question? | shanabit | Pro Tools 10 | 4 | 12-15-2011 10:43 AM |
New to pro tools, I have an input/ monitoring question | mchristofi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-14-2008 05:32 PM |
Analog Input Monitoring Question | SolidBodySound | Tips & Tricks | 3 | 08-04-2008 09:42 AM |
