Old 01-26-2011, 02:41 AM
rinconenclave rinconenclave is offline
Default Bluetooth and PT9.0.1
I'm only using digi and updated bomb factory plugins and have freezes while tracking or recording.
I use a new mac pro with bluetooth mouse. Is it possible that bluetooth causes the problem?
Thanks in advance
Certified Operator
Protools 9.0.1
Digi 003 rack +
Mac Pro 8-core 8GB RAM
OSX 10.6.6
www.rinconenclave.com
Old 01-26-2011, 03:44 AM
slater05 slater05 is offline
Default Re: Bluetooth and PT9.0.1
I believe that it's not recommended that you use Bluetooth while using pro tools, but I use the new magic mouse also and it works fine for me
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 01-26-2011, 04:37 AM
ejwells's Avatar
ejwells ejwells is offline
Mac Pro/PT 9.0.1/Magic Mouse here...no issues
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 01-26-2011, 04:43 AM
Yeah, I'm using the new magic mouse and now trying in my laptop and i don´t have problems, so probably is not the bluetooth connection. I have to try another things, such us my fw800 to fw400 converter...
Certified Operator
Protools 9.0.1
Digi 003 rack +
OSX 10.6.6
Old 01-26-2011, 11:26 AM
Park Seward's Avatar
Park Seward Park Seward is offline
I'm using a Magic Mouse on my MacPro with no problems.
Did you uninstall and then do the complete install of 9.0.1? 10.6.6 is not qualified yet but it seems to be working for most if not all.
What steps have you tried while troubleshooting?
http://duc.avid.com/showthread.php?t=193636
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-26-2011, 12:02 PM
Dirt_ Dirt_ is offline
Ahem...
http://duc.avid.com/showthread.php?t=293004
-Mac mini i7 Quad 2.3, 4g ram, OSX 10.10.2, PT11.2.1, iLok 2.
-Apogee Quartet, 2 Profire 2626's.
Old 01-26-2011, 12:38 PM
I've installed PT9.0.1 directly over my new MacPro 10.6.5 and I have the problem since the first moment.
Yesterday I've installed 10.6.6 as soon as I saw that was qualified by Avid, but the problem persists.
I have the problem while tracking, inserting plugins, recording.. or doing nothing (two days ago i went for a coffee and when I came back PT was closed).
My issue is that sometimes I don´t have problems during 4 hours with hard mixes and sometimes I have problems every 15 minutes, so I don´t understand.
I`ve tried to recreate the problem by myself, but I couldn't. I´ve changed the playback engine settings without success
I remembered some troubles years ago in versions 6,7 and 8 but I've always found the solution.
Anyone knows if there are any problems with fw800 to 400 cables or adaptors or with 003 rack+ and PT9? I will try to buy a new cable and change the cable...
Thanks for your answers!
Certified Operator
Protools 9.0.1
Digi 003 rack +
OSX 10.6.6
Old 01-27-2011, 01:36 PM
Great. That post about 10.6.6 being qualified came over 12 hours after my post. Hope they are working on 10.6.7 now.
Park
Old 01-27-2011, 01:38 PM
Did you check for incompatible plug-ins? Not just the plugs you are currently using but ALL the plugs installed in your computer.
Park
Old 01-28-2011, 12:34 PM
I've moved the rest of the plugins to the unused folder but the problem persists.
Since yesterday I change the firewire configuration: Instead of a fw800 to 400 adapter for mi digi003, I'm using my Lacie Quadra d2 disk to make the conversion from 800 to 400.
For the moment I haven´t had the no-explain freezes, but I had 2 stops about firewire overflow, so I want to buy a new fw800 2 400 cable adaptor to try to solve all the problems.
As soon I get it I´ll inform all of you. Thanks for your comments!
Certified Operator
Protools 9.0.1
Digi 003 rack +
OSX 10.6.6
FS: LMP Bluetooth keypad, new in box jeremiahmoore Buy & Sell 2 11-02-2012 02:39 PM
USB Bluetooth Adaptor timcorder VENUE Live Sound Systems 0 07-15-2008 05:44 PM
Bluetooth with le? midiman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-15-2006 12:32 AM
Bluetooth and Instability? Mount Royal Pro Tools TDM Systems (Mac) 1 09-09-2005 06:14 AM
Bluetooth and MIDI birdFEEDER MIDI 3 10-29-2003 11:43 AM
