Old 04-25-2005, 05:21 AM
Digi2004 Digi2004 is offline
Default Midi lagging behind in 6.9LE
Problem:
I am triggering a soft-synth from a midi track in Pro Tools 6.9LE and there is a delay between the "note on" and the time that you actually hear the audio output.
I have heard of this sort of problem when triggering external hardware synths but I have not had this problem prior to installing 6.9LE (over 6.7LE).
I have a 002 & a Powerbook G4 with 1 Gig RAM and never had noticeable problems of "lag" when triggering midi instruments (either hardware or software). Therefore:
- Is there some sort of "automatic delay compensation" setting that has been introduced in 6.9LE that is perhaps causing this problem ?
- If not, what can I do to eliminate this problem (other than shifting the midi notes to the left!).
Thanks for any help.
Nigel
Old 04-25-2005, 07:39 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: Midi lagging behind in 6.9LE
When installing 6.9, did you check that the hardware buffer remained at a lower amount ( 128) ? or did it reset to 1024? Lots of prefernces need to be redone when upgrading.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Midi notes lagging/hanging/sustaining PyneBoxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-08-2012 08:42 PM
Midi lagging in Ableton Live 8.2 xterraguy MIDI 0 07-04-2011 06:24 PM
PT is lagging soundwalker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2007 06:50 PM
midi track lagging robsubway Pro Tools TDM Systems (Mac) 3 12-17-2006 12:37 PM
Lagging plugins rogmidd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-15-2006 10:53 AM
