Eleven MK II (Software)
We have finally achieved parity between Eleven Software and Hardware! Now you can track with your 11R for the improved response, and instead of Re-Amping through the 11R, simply slap Eleven MKII on the Dry Guitar track and dial up your tone.
This is pretty awesome, can't wait to try it. If you already have Eleven (software) you can upgrade for a very nice price until Dec. 31, 2016. Check it here http://www.avid.com/US/products/eleven
Re: Eleven MKII (Software)
I think the MKII plug-in surpasses the Rack with multiple-cabinet support.
Ok, so, I have an 11R, Pro Tools 12.3 on El Capitan. My 11R is still not recognized by El Capitan. The drivers download page said "Updated 11/11/2015" hours ago and it says June 30 2015 now. But, when I connect my 11R PT has the 11R window on top. So it knows it's connected but it won't recognize it as an interface. Will 11R Mk2 fix anything? Or is it just the 11 plugin with a couple of extra cabs and amps?
Thanks in advanced for the answer. And one more thing, is Avid still going to release driver for the 11R so that it may be used as interface in El Capitan?
15" Mid 2014 Retina MacBook Pro i7 2.2ghz 16gb Ram 256 Flash Pro Tools 12.6 11R EQP-WA, WA76, Daking Mic Pre One |
My money's on Yes....will get updated drivers, BECAUSE, they are still releasing features for the box...that's the best sign by far...... Obviously none of us can say for sure, but it's pretty certain at this point
Any Idea if you can recall the eleven rack embedded settings in the mkII plugin? That would be pretty awesome and make it worth the $50 upgrade instantly.
You can record it dry, and then change it as needed with the plug. Which is better than embed.
That was my main issue with the plug for years, you didn't have the same expansion pack on the software as you had on the box....
Probably a dumb question but will the Eleven MkII plug-in work with Logic ProX?
Thanks
MacMini with 16GB ram Mac OS X 10.10.5 Logic Pro X Seagate 500GB GoFlex Pro 7200rpm Firewire 800 Ultra Portable Drive Audient iD22 and Focusrite Pro 40 Interfaces Focusrite Red 3 compressor Lexicon 300 Digidesign Eleven Rack Waves Gold Bundle • CLA Classic Compressors • Slate FG-X, VBC, VCC, VTM Slate Trigger EX • Superior Drummer 2.0 |
Doubt it, it's AAX format.....does logic run AAX format?
Logic only hosts AU. All of the AVID branded plugins are AAX only, they don't have AU or VST versions.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Yeah, I'm in.
I often copy the dry track to another and use Eleven plugin on it to get a dual amp setup sound. This is going be be even better!
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob Squaw Creek Road Studio Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1) | M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) | 3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 | Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X | |
Eleven Rack Firmware/Software Question | bradley.jacobsen | Eleven Rack | 6 | 01-24-2014 12:00 AM |
Required software for Eleven Rack | jvining | Eleven Rack | 10 | 12-28-2013 01:19 PM |
Can I sell Pro Tools 9+10 software that came bundled with Eleven Rack? | krubel54 | Eleven Rack | 4 | 06-25-2012 06:16 AM |
Mute button on eleven rack, software window | Sam C | Eleven Rack | 3 | 12-04-2011 01:03 PM |
Can eleven rack GUI/Software be used out of PRo tools? | trock | Eleven Rack | 7 | 10-02-2011 09:53 AM |
