6.1 mouse scrolling disappointing
This was a feature I was very much glad to get back. But it lags horribly for me in 6.1 on my g4-400.
Slow...latent...laggy scrolling. Safari, explorer and other apps just zip on down the page when scrolling....but with PT you have to spin the dang wheel off to get to the bottom of a page. Whats up??
Kevin Perry Chameleon Music |
Re: 6.1 mouse scrolling disappointing
oh give it a rest
Huh? |
Kevin, I can't get anyone to answer my thread. Did you experience a slow up, speed up, or same speed in system response moving to PT6 fromo 5
Doug |
Make sure you check your mouse settings cause mine was slow at first. It was set to scroll up or down by three lines and I changed it to 1 page and it works just like it did in PT5. This is kinda cool cause you can choose how fast you want it to move up and down. I am running a Microsoft Trackball on a 1Ghz Powerbook in case you are wondering. I don't think it has anything to do with the speed of the computer though you just need to check the settings. Hope this helps.
- Jason |
Kevin,
Did you have any luck trying out what I suggested?
- Jason |
yep, checked it myself with ym wireless microsoft mouse. Just adjust the settings.
In fact I have it set up to scrol horizontally, and pressing the wheel for scrolling vertically. Works fine here
Huh? |
I tried adjusting the scroll speed. If you scroll slowly it moves in pretty big intervals down the page. Works great. But when I scroll too fast ...it's like the intervals suddenly get very small. S0 when scrolling fast it takes all day to get to the bottom. It's a logitech mouse so maybe there is a compatability problem.
Thanks vaphoron.
It is pretty slow, I have mine set to the fastest scroll setting and it still takes a ton of scrolls to get anywhere.
ProTools uses a noticably smaller scroll increment than other apps, could this be tweaked in a future version? |
Also note that the command key serves as an "increment slowly" modifier, much as it does for slider and knob tweaking. I don't know if they included that fact in the What's New guide or whatever. So if you set your prefs to scroll at the highest rate (which, it sounds like, isn't high enough), you can still get more precise scrolling via the command modifier. The other modifiers do other fun things, too. [img]images/icons/cool.gif[/img] Eric Miller Digi Engineering |
Take 2 - Mouse scrolling in 8.01 is terrible | leonardrock | Pro Tools M-Powered (Mac) | 2 | 10-02-2009 08:37 PM |
'shift' + mouse roller for scrolling | Phil Jeffers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-22-2009 10:08 PM |
Logitech Marble Mouse (Scrolling) | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-04-2007 02:54 PM |
Midi Pauses when scrolling or using the mouse. | ewan | Pro Tools TDM Systems (Mac) | 2 | 06-16-2006 01:07 PM |
6.1.1 mouse wheel scrolling problems | Kirby B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-12-2004 06:39 PM |
