Old 10-04-2017, 10:54 AM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Default Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List"
Is it really possible that Pro Tools has no built-in Keyboard Shortcut to toggle the three window panes in the Edit Window, "Track List", "MIDI Editor Pane", and "Clip List"? It seems that the only window pane is the Universe View that has an assignment (opt+7)
I guess I have to create my own Keyboard Shortcuts with the Keyboard System Preferences or the BetterTouchTool app.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 10-04-2017, 12:03 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List"
Command = (Mix & Edit toggle)
Control = (MIDI editor)
You can also set up recall window sets to most anything (Window Configurations)
i.e. all tools, eco tools, 1 monitor, 3 monitors, mater tools
Decimal point < number < Asterisk (Recalls)
Old 10-04-2017, 02:18 PM
Thanks for the answer, but using Window Configuration feature would be a cumbersome workaround.
The Edit Window has four window panes and to provide the functionality to toggle each window pane individually would require too many (insert math here) configurations to have not only each one with and without, but also any other combination. This is just not practical. In addition, to recall a Window Configuration, you have to type a sequence of minimum 3 keys.
Right now I have set up 3 key equivalents with BTT, one to toggle the Track List, one to toggle the MIDI Editor Pane, and one for toggling the Clip List. Same functionality as having opt+7 to toggle just the window pane for the Universe View. I was hoping that there was a hidden Keyboard Shortcut in Pro Tools, but I guess not (yet).
Edgar Rothermich
Issues using "Select unused->Clear" from the clip list in 12.8 DontLetMeDrown Pro Tools 12 4 08-21-2017 07:36 AM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
Region List "Bins" / "Folders" Styles Bitchly Pro Tools TDM Systems (Mac) 1 06-18-2010 01:22 PM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
