003R - No output from monitor, but headphone OK
Hi folks,
Been running my setup for a few years now without any probs. Today, I can't get any audio from my 003R monitor output. The 003R headphone out is working fine. When I route audio through the Mac, it works fine. Any ideas what's going on? I suspect I may have a faulty 003R. My setup is 003R + Command8
My music Hardware 21.5" iMac 2.5GHz i5 24Gb (mid 2011), 003 rack, Roland TD12KV, Command8, Axiom 61, Maxtor OneTouch4 FW/750Gb/16Mb/7200rpm (audio/session drive) WD 1TB MyBook Studio (backup) Software OSX 10.13.6, PT2018.12.0 |
Re: 003R - No output from monitor, but headphone OK
Assuming you've confirmed your monitors and respective cables are good, check the alt/control room button on front panel. None of your I/O settings have changed? If not one of those two, try switching monitor out cables to the alt/control out and check for audio.
Thanks folks... I'll check those option this evening. Much appreciated!
Er, you know that Alt-CTRL button, well, er, that was the problem. I never touch the settings on the front of the 003R, so must have hit this one by accident.
Thanks for the help!
aha. if I only had a nickel......
It's nice when something turns out to be an easy fix. Even if it means I'm a muppet
Thanks again!
No headphone output ONLY when trying to monitor audio I'm trying to record | fdean | Pro Tools 11 | 5 | 11-18-2015 05:34 AM |
No headphone jack output - Meters showing output | Hotcrazyfruit | Eleven Rack | 6 | 05-06-2012 12:09 PM |
mbox 3 monitor and headphone output | Brad Summerfield | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-02-2012 07:54 AM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
003r to headphone amp | roziel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-29-2008 09:42 PM |
