Old 06-02-2011, 10:32 PM
TieDyedDevil TieDyedDevil is offline
Default Re: Main Outs
Dave, the clock thing is a known defect. There are several threads on DUC covering the symptoms, etc.
I'm under the impression that Avid will make good on this regardless of whether you're the original owner.
Try sending a PM to Chris Townsend.
Old 06-02-2011, 10:41 PM
dmock66 dmock66 is offline
Thanks for the advice Dave.
Chris - the PM functionality on my account has been "disabled by Administrator". Thoughts on my clock issue? I appreciate anything you can do.
David
Old 06-03-2011, 06:59 AM
Default Clock Issue
Chris - my account doesn't have PM authorization. Is there anything we can do about my 11R clock issue?
Old 06-03-2011, 01:27 PM
singtall singtall is offline
i normally run at 48khz for everything possible, so that issue wouldn't effect me 99% of the time. when it would effect me is after mixing down and i'm testing the final 44.1khz 16bit master before burning a cd. unless you have another interface for that reason, i would call AVID and see about sending it in for repair. the crystal that causes the problem is fairly easy to replace and is only a couple of bucks, but i have heard of stories that AVID replaced the entire eleven rack instead of repair it...i would hope for that!
call AVID.
Digi002 rack main outs vs monitor outs studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-03-2012 07:46 AM
Problem with 002 main outs as well as head phone outs? wiseal1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-10-2009 11:36 AM
001.....Main Outs or Monitor Outs G. Klopfenstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2004 08:07 PM
main outs vs. others freakuincy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2002 06:54 AM
How can I have the monitor outs and main outs to the same input? voxpitch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-15-2001 09:16 AM
