Old 01-22-2010, 02:44 PM
firsty33 firsty33 is offline
Question Virtual Intrument "Boom" Issue
I'm familiar with Boom, but am having an issue with the loops. When I create a loop on "pattern edit", I put that pattern as a whole note into the midi or instrument track on the edit timeline. That much I've figured out, but I can't understand this: The loop will play, and the snare will hit on the first beat of the next bar, even though it's not created in the pattern! It keeps coming up and there's no "red dot" whatsoever. Any advice?
Thanks!
-Justin
Old 01-22-2010, 02:49 PM
Default Re: Virtual Intrument "Boom" Issue
Boom>Setup is Sync Mode set to Beat? Ummm... what about OS X version and Pro Tools, are these compatible?
filosofem
Old 01-22-2010, 02:54 PM
filosofem
I believe so, I've tried all options in the settings menu for Boom. Still doesn't work. I'm running 8.0.3 on snow leopard.
Old 01-22-2010, 03:35 PM
That Whole Note trigger is in 4/4? Have you tried creating a new session with creating a new Boom pattern?
filosofem
Old 01-25-2010, 12:20 PM
filosofem
Yes I have, and now it seems to work. I think it's a bug in 8.0.3., sometimes boom acts plain weird.
"Boom" kick won't work Codycougar91 macOS 3 03-18-2011 01:28 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
Power harness issue and "Rev "g" series 002R mcgwd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-19-2010 10:10 AM
Boom and "pattern snippets" Stig Eliassen Virtual Instruments 13 06-05-2010 04:23 PM
Loading Drum Samples into "Boom" erockrazor Virtual Instruments 5 02-27-2009 05:02 PM
