Old 04-10-2009, 01:56 AM
Scotauto Scotauto is offline
Question 9128 6101 errors
I a relatively new user of Protools LE8 and with the need to "talk" with other studios I have finally bought the program. I have been looking forward to the system especially the new design etc. (which looks great!" however I have nothing but problems with it. If I run a session with recording etc. there are no problems but as soon as I add a plugin, whether it is from the bundled protools plugins or from my Universal Audio powered plugins there are error messages almost every time, usiually if I try and compare the effect with no effect added (Bypass) With 33 tracks of audio runnig my CPU is max 8%, Disc is 17%, UAD-1 cards are at 2% but still I recieve a message like A CPU overload error has occured (6101) change the buffers etc. When I say OK to the message I can work again until I use the bypass button then the same problem!! If I change the buffer settin to 2048samples I can work for a bought 3 bypass clicks then error message again. If I then change the buffer to 1024samples The audio does not comeout of the speakers although all the meters are moving.. I then have to change the buffers again to start a signal out of the speakers again. This is a big problem. Is it a bug in Protools LE8 that there will come a fix for? (very soon I hope) or do I have to go back to using Cubase which incidentally has absolutely no problems!
Old 04-10-2009, 02:26 AM
Default Re: 9128 6101 errors
I forgot to mention a quick fix is to tick the RTAS Engine Ignore errors During playback/recording. This is not perfect though
Old 04-10-2009, 03:47 AM
The Dougfather The Dougfather is offline
Are all of your plugins 100% compatible with Pro Tools 8?
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 04-10-2009, 05:55 AM
It happens with only the bundled plugins from Digidesign and no others are enstalled.
Powermac G5, 1.8 Ghz processor, 4.5 GB DDR Ram, OSX 10.5.6, Protools LE 8, 2xUniversal audio UAD-1 DSP Cards, Digi 003, M-box2, Edirol PCR-800 midi keyboard controller, Yamaha Motif, Focusrite Saffire Pro 26 I/O, I-Lok
www.studio3.dk
Old 04-10-2009, 06:36 AM
LUISMI LUISMI is offline
Do a clean uninstall of PT 8 and install it again, repair permissions,restart.
Best luck
Old 04-10-2009, 12:04 PM
I've done that already. It doesn't help
www.studio3.dk
Old 04-10-2009, 01:42 PM
Are you recording to a second hard drive? These errors often happen when trying to record to the system drive.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 04-11-2009, 12:40 AM
yes I'm recording to a second drive which hasn't been a problem before. I know several other studios in my areas also having the same problems with error messages. Could it be because I have OS X 10.5.6 installed?
www.studio3.dk
Old 04-13-2009, 02:13 PM
I ran the 30 odd track session and dubbed two guitar tracks onto it. I was working in Protools for about 2 hours and not one problem. Excellent! But if I come back to it at a later stage then errors all the time. Help!!
I've also tried one track 4 minutes of ez drummer (instrument track) and this worked fine until I bounce it onto another track as audio. With the buffers set to 1024 it can't get through this process without stopping and giving an error message. Surely this can't be right. Is OSX 10.5.6 approved for Protools?
www.studio3.dk
Old 04-13-2009, 02:39 PM
DigiTechSupt's Avatar
What happens if you reduce the number of processors dedicated to RTAS in the Playback Engine?
Avid Audio Tech Support
Support FAQ
10.3.8 and 6101 / 9128 errors Muzoid Pro Tools 10 3 01-27-2014 05:23 AM
Several 9128 and 6101 errors mdiazbass macOS 10 01-02-2013 01:19 PM
PT 10 6101 and 9128 errors spaceman macOS 13 03-12-2012 02:03 PM
6101 AND 9128 ERRORS LUISMI 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-09-2008 06:24 AM
6101 & 9128 errors on M-Powered 6.8r2 travmac Pro Tools M-Powered (Mac) 4 10-12-2005 03:23 AM
