Re: Backup Vocals
Heya!
This is my personal "recipe" but there are dozens of different ones, it really depends what you need. I use to work with loadza backing vocals in my tracks. First of all, I try my best to take the cleanest signal, then i just apply Waves L1 on each.I "pan" them" and adjust the levels.Set all the bvs (backing vocals) channel output to a free bus, group them.I set a stereo Aux track with the later bus as Input, leave the fader at 0, then trim the group level (touching one of the bvs track, moving all the others proportionnaly!), to avoid clipping. I put a stereo Strip Channel Plugin (i.e SSL Channel Strip) then I make an overall EQ and Comp (SSL really "glue" the submix). I set a send (via another free bus) on EACH bvs channel to a reverb (long or short, just depending on the wanted effect) set their level and panning. Create a new Stereo Aux inserting a Verb Plugin (be careful, plugins like Waves True Verb must have the direct switch off! Or some phase issue and kind of Flanger can occur, but it can also be a desired effect.) Then set your Verb Channel level in the mix. Another tip about reverb; if your reverb plugin doesn't include PRE DELAY feature, you can put a Time Adjuster just before the verb plugin.Cause because of the speed of sound in real conditions, reflection and reverb don't occur exactly at the same time as the dry signal. Hope it helps!
Green Room Studios, France Mac Book Pro i7 15"4 Mac OSX 10.6.6 PT 9.0.2 DIY Intel Core 2 Quad, P5B Premium,DDR2 6GB, Win 7 Ultimate. PTLE 8.0.4 002R Unit and MBox Mini SSL XLogic Alpha Channel. SPL Goldmike valve Preamp. DBX Analog Compressors, Gate and Eq. Monster Cables Home made & Neutrik Patchbay. Brauner, Shure, Seinnheiser and T.Bone mikes. Tannoy 8D Active monitors. |
Breathy vocals and vocals in general | rckandorroll | Tips & Tricks | 3 | 01-30-2007 10:13 PM |
Breathy vocals and vocals in general | rckandorroll | Tips & Tricks | 5 | 01-30-2007 10:10 PM |
Lush Backup Vocals | mushmouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 09-22-2005 05:22 PM |
Panning backup vocals | j20056 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-22-2003 06:34 PM |
TRAVAN Tape Backup - compress audio backup or not ? | stoneinapond | Pro Tools TDM Systems (Mac) | 2 | 11-28-2001 12:35 AM |
