Old 02-16-2020, 01:32 PM
bifbangpow bifbangpow is offline
Default CPU limit?
I'm trying to limit the amount of memory reserved when PT 11 runs so that I can livestream it on twitch. But in 11.3 theres no CPU limit function in the playback engine menu. Can someone help me do this?
my specs:
iMac 2020
3.8Ghz 8-core Intel core i7 processor
Catalina OS
ProTools 2020.12
Scarlett Focusrite
+ Saving to External Harddrive
http://MayMcDonoughMusic.com
Old 02-16-2020, 09:36 PM
Default Re: CPU limit?
What are you trying to do?
Are you looking to limit CPU or memory? What exactly happens if you don’t? Pro Tools crashes (exactly what error)) or twitch is not steaming smoothly?
Pro Tools will Automatically take care of CPU Workload placement (But 11 is worse at thread balancing than recent releases). You can also significantly reduce CPU load with track freeze and commit in later releases.).
Better systems specs may help as well. Post a SiSoft Sandra report, we have not clear info on CPU specs or Memory amount.
Old 02-16-2020, 10:35 PM
Livestream tells me offline processes such as freeze and commit are not an option. However I can confirm 2019.x releases are much much more cpu effective than any PT11/12 version you can find.
WE TV -10 limit on a 5.1 mix? Brandonx1 Post - Surround - Video 16 06-22-2010 02:02 PM
PT and 4gb ram limit Boe Larsen Pro Tools TDM Systems (Mac) 9 12-24-2009 04:43 AM
How Much RAM Can 6.4 Use? Is There A Limit? sndchck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-17-2005 09:00 AM
If you had an $800 limit... likegluelikecrew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 07-30-2004 08:23 AM
CPU Limit Musick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-02-2004 02:15 AM
