Old 12-26-2001, 09:16 AM
Target Earth Ent Target Earth Ent is offline
Default Question of Fader Peak Levels..... And Volume of CDs Pressed
ok.....
I just switched to the Protools format...
got the waves gold thing goin on....
soundin good....
last night I finished my first protools song and went through the entire process to CD. The faders seem to show red very very easily. But I considered what the red was telling me. However.... the CD sounds good... but is significantly lower then the material I've done in my old but trusty VS. Should I ignore the Red and push for the volume I want while listening out for distortion? My Test for my albums is on this CD player in the studio. When I put the volume on 5... it should be significantly cracking. What should I do?
Old 12-26-2001, 09:28 AM
ReniuR ReniuR is offline
Default Re: Question of Fader Peak Levels..... And Volume of CDs Pressed
You got it. Use the meters as a guide, but never forget that if you don't hear distortion, it most likely isn't clipping.
Also, protools has softclip built into every channel strip including the master. This acts kind of as a limiter. So, as well as distortion, also listen for if it's limiting too much on your master.
-ReniuR
www.disposableproductions.com
Old 12-26-2001, 09:34 AM
Allen Hallada Allen Hallada is offline
And put your Waves L1 to use here. Should give you a little boost in the end.
Allen [img]images/icons/smile.gif[/img]
Old 12-26-2001, 09:43 AM
keny keny is offline
The peak level indcator represents 0db and not necescarily distortion. Use a limiter on really hot tracks though, trying to get the signal as loud as possible without peaking. Good luck with the C1 though, that thing is a complete can of worms. I've read the manual threee times and still don't get it. I use the digirack limiter because it takes up less cpu.
just to toot my own horn, I am in the process of relocating to Los Angeles and lookign for a job, so if anybody knows someone who can help me get established as an audio engineer and producer, check out my creds at http://www.kenyruyter.com and call me 310-909-9115
myspace page
Old 12-26-2001, 10:18 AM
marcusb marcusb is offline
don't forget the channel meters are pre-fader by default !
the softclip is handy for the OCCASIONAL transient on say an accoustic kick or snare track but realistically aim to optimise your gain structure to avoid this
look at your inserts if you are doing a major boost on an EQ, or any other insert processor, set the ouutput gain of to avoid clipping. Ie. with the waves REQ, if you are doing significant boosts you SHOULD always reudce the output gain to compensate.
BTW please, for the life of you, don't use the L1 as a crutch ... its good for finalising rough or final mixes but if you are dropping more than 2-3db on peaks go back to go and start again.
Marcus - ofthecoalitionofgoodmixesthataren't trashedbymisuseoftechnology [img]images/icons/smile.gif[/img]
LEQ(m) levels not VU or Peak.... georgia Post - Surround - Video 27 04-05-2012 03:28 PM
Levels Peak on Master Fader NonSpecific 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-09-2006 04:56 PM
Question about Master Fader levels- help owusumenes1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-09-2005 02:33 PM
Waves' S1 on Master fader question: Huge volume drop? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-07-2003 10:34 PM
Peak levels on Master fader during mix. Hardnox Tips & Tricks 7 11-05-2001 08:59 AM
