Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 10-07-2019, 09:23 AM
razorgaze razorgaze is offline
Default PT 10. Faderport 8. PT Recognizes HUI but no display, faders don't recall...
Everything's been running great and then about a week ago the faderport 8 stopped displaying info in the LCD, recalling fader positions when launching sessions, some lights work, some don't.
Oddly, all the buttons work. When I touch a fader, the DAW fader in PT suddenly jumps to the current position of the hardware fader and then follows motion.
I've factory reset, uninstalled/reinstalled drivers, uninstalled my scarlett 18i20, reinstalled pro tools, swapped out usb cable, tried different ports.
Here's the weird thing. If I boot the faderport into studio 1 mode, everything works perfectly - display, lights, etc.
I've looked everywhere! The ONLY thing different is i added my piano sustain pedal to the footswitch to start/stop playback. thinking this might be the issue, i've disconnected several times and still the same issue.
is there something in pro tools that i've turned off by mistake?
thanks!
Old 10-14-2019, 02:54 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: PT 10. Faderport 8. PT Recognizes HUI but no display, faders don't recall...
Is Eucon enabled?
That would eliminate audio meters/HUI but not faders unless Eucon is controlling elsware
Old 10-14-2019, 03:15 PM
It's not checked but when I try to select it, it says no hardware. Oddly, i clicked on the VENUE tab and under advanced network settings, there's IP and port info populated. I don't have a venue system, unless this is a default? I can't seem to remove the info
Old 10-15-2019, 05:17 AM
junkgear's Avatar
junkgear junkgear is offline
Double check that you have the right midi ports selected in the HUI section of PT. It's pretty easy for the FP8, but maybe something changed.
If not, maybe unselect HUI in PT, exit, restart PT and select the FP8 again.
Will
System Details
Old 10-15-2019, 07:53 AM
ah, if only that was the solution. So, i've uninstalled/reinstalled pro-tools - hell, I even wiped my OS and started over. Nothing. I spoke to presonus and they say it's not hardware related since when i boot into the studio one mode, everything works as intended.
It has to be hardware related, no?
Old 10-15-2019, 08:20 AM
The fact that it works in Studio One suggests the hardware is fine. Is there a factory reset option for the FP? Or maybe review the settings in Pro Tools Peripherals? It would also be worth trying another USB cable.
Old 10-15-2019, 08:30 AM
yes, reset and tried multiple cables. Here is my theory - the probs started when I incorporated the foot pedal.
The reset is interesting. It reverts to the original firmware. From there the software, when installed, alerts you to the availability of new firmware.
What i've been thinking is remove the foot pedal, reset, don't update the firmware and see if i get a different outcome.
external recognizes usb but not eSATA???? greenwood63 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-03-2011 04:41 AM
Nothing recognizes my Digi 002 triplethreat23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-21-2007 05:28 PM
D-Control Display Groups On Custom Faders? GlennR01 ICON & C|24 7 03-09-2007 07:54 AM
Power Harness Recall of the Recall ! ChuckLogan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-21-2004 09:06 AM
Recall all AUX Faders, on Demand airwavejoel ProControl, Control|24, Command|8 10 03-10-2003 02:43 AM
