Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 09-26-2019, 04:54 AM
Default Restoring tracks - what's going on?
I'm putting this here as it's happened across PT 11.3.1, 11.3.2 and 2019.6.
When I open sessions I'll see message on the screen that PT is restoring tracks and usually no big deal. Every so often it'll happen where it takes a real long time to restore a track or tracks but it always restores and the session plays just fine.
It's happened on my old iMac system and my current setup with the 2012 cheesegrater. Different cpus (3.4 GHz quad core i7 in the iMac and 3.46 GHz hex core in the cheesegrater). Plenty of ram in both machines. Happens whether the session is on the system drive or separate drive the latter being my usual way of working when not troubleshooting. Big sessions aren't always an issue as I've had 90+ track sessions with mixed audio and unrendered vi's load up quickly but smaller less than 20 track session take enough time I can go make a cup of Earl Grey.
I can close a session that takes a long time to restore it's tracks, quit PT, reopen that same session right away and it still takes a long time to restore tracks. Nothing spectacular in the way of plugins; mostly compression on busses and reverb on an aux with sends to said aux.
So you can see there's nothing much in common except for PT and even then it happens across different versions. Daw not online and no wireless going on. Drives don't sleep nor does the machine.
The question becomes: what is going on when PT is restoring tracks? Is this happening for others? Or is it another one of those 'nature of the beast' things
Jack
QAPLA!
Old 10-01-2019, 11:36 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Restoring tracks - what's going on?
What happens when opening the session with all plugins disabled?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 10-02-2019, 04:27 AM
Doesn't matter. Still takes it's sweet old time and sometimes it happens on sessions with only two plugins that are active. I tend to not use a lot of plugins in my work once everything is audio.
So no one really knows what's happening when PT is restoring tracks when opening a session? Restoring what? In some operating systems you can engage verbose mode when a system is booting so you can see what's going on and then you see all the gory details. I want to know the same about this so I have some idea of why sometimes it takes a lot longer than I think it should to re-open a session on the same computer & setup.
Jack
QAPLA!
Old 10-02-2019, 03:22 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I think it might have to do with the graphic memory file for the waveforms. if i have a session that loads slowly first i see how many session save files there are(sometimes one is corrupt so i will delete any i dont need) then i delete the file that has the waveform memory and that usually works. IDK for sure what's going on under the hood either so take it with a grain of salt.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 10-02-2019, 04:54 PM
It's weird as I've had sessions with 30 or so tracks and about a dozen plugins sprinkled about the session load quickly but smaller 10 track sessions with only two plugins take a long time (quadruple the previous session) to restore tracks. Max session length of 5 minutes in both cases.
Jack
QAPLA!
Restoring Tracks slow clancychris Pro Tools 2018 1 11-23-2018 01:59 AM
Restoring Tracks, Rainbow Wheel? TonyFlyingSquirrel Pro Tools 12 0 03-28-2015 11:56 AM
Help Needed - restoring tracks cruisemates Pro Tools 10 4 08-01-2014 04:18 PM
Restoring Tracks, Please Help. ves1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-28-2007 10:18 AM
Pro Tools Not Responding when Restoring Tracks dtsamples 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-06-2006 01:49 PM
