Old 04-25-2012, 07:48 AM
blujway blujway is offline
Default pro tools 10 HD stuck at Initializing Hardware (DSI)
PT 10 CANT LAUNCH , GETS stuck on the 'initializing hardware ' status.
No digidesign hardware selected in sound in or out
Tried holding N key upon launch
system profile sees the pci cards.
Digi test does not seem to do anything
I have safe AND clean un installed , reinstalled PT,
trashed the normal prefs and p lists
ANY ideas ??
Appreciate the help .
Mac 6 core westmere 10.7.3
PT 10.1.2
HD 192 w accel
all ilok licenses fine
all ilok drivers installed
Old 04-26-2012, 01:16 AM
LukeHoward LukeHoward is offline
Default Re: pro tools 10 HD stuck at Initializing Hardware (DSI)
ANY ideas ??
PT 10.1.2
HD 192 w accel
Did it used to work? When I had this problem this was the cause:
http://avid.force.com/pkb/articles/e...ssage/en210585
https://lukehoward.com/
Old 04-26-2012, 11:54 AM
Thanks Ill check,
def used to work , took them carefully out of one mac to the new mac.
old mac no problem , new one this issue Ill examine the cards
j
Old 05-15-2012, 04:28 AM
revsound revsound is offline
Any answers for this? I'm having the same problem currently
PT HD8 - Stuck at Initializing Hardware (DSI) RoofTopLuki Pro Tools TDM Systems (Mac) 5 07-07-2014 11:03 PM
Pro Tools 11 stuck on "Initializing Audio Engine" AudioDrummerGuy Pro Tools 11 10 01-19-2014 12:47 PM
Unable to boot Pro Tools V8.1 past Initializing Hardware (DSI) stage Barry Sage Pro Tools TDM Systems (Mac) 2 08-05-2013 10:10 AM
Pro Tools 10 not opening stuck on initializing machine control!! wullie macOS 4 11-20-2011 08:39 PM
Pro Tools 8 LE not opening stuck on initializing machine control!! digartisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-29-2009 04:33 PM
