Old 07-08-2018, 10:52 AM
Pingafuego Pingafuego is offline
Default Re: Difference between "Mirror Analog" and "Rig Outputs"
Originally Posted by Benoni View Post
The Rig Outputs are just that, the whole rig. Analog is what's coming out of the Main Outs. Are you using the Eleven Rack standalone or with a DAW? If you use it with a DAW you will instantly hear the difference.
  • Mirror Analog
    The same signal that is being sent
    to the Main Outputs will be sent to the digital
    outs.
  • Rig Outputs
    The left and right Rig outputs are
    sent to the left and right digital outputs respectively.
Page 91 of the user manual if you want to read further
http://akmedia.digidesign.com/suppor...v90x_71670.pdf
Hi Benoni, which is the best setting using the Eleven Rack as a Pro Tools USB interface?
I could not find this information in the user guide.
Thanks!
Old 07-09-2018, 09:20 AM
Benoni's Avatar
Benoni Benoni is offline
Thanks!
This wouldn't affect you if you are using the 11R as a USB interface. These settings are for SPDIF.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 07-12-2018, 03:23 PM
Ok, thanks!
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
setting the "output to amps" outputs to "rig no cab" affected also the (xlr) outputs! italianguitar Eleven Rack 15 03-20-2012 01:57 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
What's the difference between "online" and "offline" editing ? stuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-21-2002 03:46 PM
AUDIOMEDIA (chips "QC", "QE" or "Q") What's the Difference ? lukemaniak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-26-2001 06:55 PM
