Old 06-28-2017, 08:26 AM
rjashcraft rjashcraft is offline
Default Re: Playback won't start at Timeline Selection Point
Was having the same issue today... FOUND THE SOLUTION by trial and error. I also thought I hit some button by mistake and it seems the "Insertion Follows Playback" button is the culprit. Needs to be unchecked. It is towards the top of the Edit Window under the pencil tool.
Old 06-28-2017, 05:46 PM
The Weed's Avatar
The Weed The Weed is offline
Or, if you're in Commands Focus Mode, the "N" key will toggle "insertion Follows Playback" on and off. Easy to hit the "N" key by mistake.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-28-2018, 06:40 AM
Karthiklambo Karthiklambo is offline
Folks go to the options menu, Down there check whether "Link Timeline and Edit selection" is ticked, if not enable it. Done!!!
Old 09-23-2019, 04:11 PM
mattdaddy mattdaddy is offline
Extremely late for this but I'm still using PT10 and once I unchecked Quickpunch under the Options tab, the timeline stopped jumping back to the start.
Old 09-24-2019, 08:18 AM
bcwiz's Avatar
bcwiz bcwiz is offline
Yep old thread, this was/is an issue on the Mac. If Quickpunch is enabled without a track record enabled the cursor behaves like this. Turn off Quickpunch if you're not recording.
  #16
Old 01-19-2024, 12:08 PM
Noteon Noteon is offline
Originally Posted by Ben Jenssen View Post
Could it be that you have enabled (a very large) pre-roll on this session?
That would make it behave this way.
I assume that the edit insertion point doesn't move back to the start when you hit play?
Thanks for this! I had an issue. Wondering what the ****... Not even cross my mind
-janne
  #17
Old 03-12-2024, 11:45 AM
thouldcroft thouldcroft is offline
I know this is an old thread, but this happened to me today. I don't really know what caused this issued, but the solution was to turn ON Dynamic Transport, then turn it OFF. After that, operation functioned as normal.
Play Start Marker Follows Timeline Selection - no effect in 10.3? Richard901 Pro Tools 10 32 02-02-2015 07:35 AM
How to punch a selection but start playback before the selection... shotgunndunn macOS 1 01-19-2012 04:45 PM
Timeline/cursor start point? BilboMcP Pro Tools M-Powered (Win) 3 07-01-2008 01:04 AM
Selection Point Playback Benjamin Golby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-07-2007 04:58 PM
Selection Point Playback Benjamin Golby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-07-2007 02:30 AM
