11R and Fast Track C600
I'm using the 11R but need more audio inputs and outputs and just saw the new M-Audio Fast Track C600. Is there a way to run both the 11R and the Fast Track C600 simultaneously? Is the 11R compatible with Pro Tools MP 9 ?
Many thanks! |
Re: 11R and Fast Track C600
no, not the way you want to. Only one interface can be the Active interface.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Many thanks. Sorry to hear that I couldn't run 11R with the Fast Track C600. Would
Pro Tools MP9 work with Eleven Rack? |
MPowered will not work with the Eleven Rack.
However, regular PT9 will work, and you can use your Eleven Rack serial number to get PT9 at the crossgrade price of $249. |
A higher cost outlay but feasible ... no?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
If you don't mind not having an Eleven Rack config window in Pro Tools then you can work with Pro Tools SE and just feed the S/PDIF out from the Eleven Rack to the C006. In this case the Eleven Rack is operating just as a stand-alone piece of outboard gear. But SE is so limited it sucks badly. "wanting more inputs" and using SE are conflicting concepts Or you should be able to crossgrade/upgrade to Pro Tools 9 from the Pro Tools LE 8 that came with the Eleven Rack -- then you will get the Eleven Rack control window working and you can separately install the C006 Driver Control Panel. If starting to spend more money looking at a higher-end Mbox or a third party interface might be a better idea. Darryl |
correct me if I am mistaken. But PT9 MP requires an M Audio interface right?
So wouldn't it be better to just upgrade to PT9 with your PTLE serial from the 11R, and have the choice of any Core Audio interface? You can even still go with the C600 if you want. I mean you can get a Fast Track C600 bundled with PT9 MP, (it usually comes with PTSE) and it will save you roughly $160, but not being tied to an interface is well worth that price. I just don't see any reason to go M-Powered other than to cut costs. And though you save a bit of money, I think as a whole you would benefit much more with just going with PT9. Also, the OP does not state how many simultaneous inputs he needs, so it's hard to say whether or not running the 11R via SPDIF into the C600 will alleviate the situation.
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM Pro Tools 10.0.0 Ableton Live 8.2.1 RME Fireface 800 Eleven Rack |
Think you have gotten some bad info. It appears that the Eleven rack & Pro Tools MP9 are compatible and do indeed work in tandem...
I also do not know what you mean exactly by "work in tandem". You mean that software using that interface, then again, no. |
10.3.3 & 10.3.4 broke Fast Track C600 I/O | shanemorales | FireWire & USB Audio Interfaces (Mac) | 6 | 05-18-2013 09:23 AM |
Fast Track C600 | muk786 | FireWire & USB Audio Interfaces (Win) | 6 | 04-05-2013 06:48 PM |
Fast Track C600 | bmryner | Pro Tools SE and Essential (Win) | 0 | 01-12-2013 07:05 AM |
Fast Track C600 | stefano.9119 | Pro Tools SE and Essential (Mac) | 1 | 12-21-2012 02:10 PM |
